rear wheel hub removal
I am installing a Big Red kit on my car and had the "brillant" idea of while-in there- check the rear bearing.
I took the 30mm nut of, but now it seems impossible to remove the hub. Am I missing something? How do I remove the hub? I did some research and evryone seemed to worry about the big nut, which I was able to remove quiet easy...but the hub is different story. Help...PLEASE
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 |
You need a slide hammer. If you remove the year hub, you'll destroy the bearing and have to replace it. Don't fix it if it ain't broke. :>)
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Thanks Mike...the problem was that I was already half way through.
Fortunately, , I was able to take it out without breaking it. I checked the bearing and looks to be in good shape...add some grease and now I am ready to install the hub again. Any tricks for the hub installation or just bang it until it's in. Thanks
The rear bearing is a sealed unit. What have you done? AFA as destroying it, you won't notice until you drive the car. What happens is one of two things: Either it comes apart (shouldn't) or the procedure to remove it dents the races with the ball bearings themselves. It won't go far in that condition.
But, if you must, you put the bearing back in by first freezing it. Then heat the arm. Now drive or pull the bearing in using pressure ONLY on the very perimeter of the bearing housing. Many homemade tools have been conjured up for this including a section of stout PVC pipe that matches the ID of the arm where the bearing fits. Others have found parts in the electrical isle of the Home Defect, or hardware store. |
I agree.
Do not for one second consider keeping that old bearing in there. The hard work is all done: the bearing is Cheep.. Do it right and do it once.. Kind regards David |
Thanks Milt.
I'll get it. I need to replace the bearing.
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 Last edited by mmasse; 07-22-2006 at 03:24 PM.. |
Hello, Mario.
You removed the hub. This will have brinnelled ( read mullered) the bearing. Kind regards David |
Thanks guys for the help. I guess stupidity has a price!!!.
This is how the hub came out And here is the bearing still in the trailing arm. Now, when I reinstall the new one, should I press the bearing in the hub first?? or in the trailing arm and then install the hub? Thanks again
Mario,
As you can see, one of your inner races is still connected to the hub. Hence you've pretty much ruined the existing bearing. You'll need some sort of bearing splitter to remove the race from the hub. You essentially need to press the bearing into the hub and then use some sort of home-made puller/press to pull the hub back into the bearing without disturbing the inner races. I'm sure once you see how this comes apart, it will be somewhat obvious how it needs to go back together. This isn't real difficult, but you need to make sure you use the appropriate amount of care to avoid damaging the trailing arm and the bearing when it goes back together. Mike
The bearing is pressed out: the arm is warmed the bearing frozen: then it almost falls into oplace..
The hub is pulled into the bearing by the stub axle after startting with a simple screw pulling device. it is imperative to keep the bearing compressed to avoid it falling apart.. Kind regards David |
Thanks again for the help.
I just finished removing the bearing from the trailing arm. I fabricated an extractor following the instructions on this forum. GRET HELP here!! Now, I still need to find out how to remove the bearing race from the hub. Any suggestions? Thanks
I have removed those races multiple times by heating it cherry red and tapping it off with a chisel(carefully and evenly).
BTW have you guys priced those rear bearings lately ? They were $40 about 5 years ago. Now they are $90 to $100.00 . Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
