-   -   Sources for steel fuel lines (http://forums.pelicanparts.com/porsche-911-technical-forum/294763-sources-steel-fuel-lines.html)
126coupe 07-22-2006 08:04 AM
I am revamping the fuel system in my 911 race car (carbs)
What is a good source for steel fuel lines?
Porsche_monkey 07-22-2006 08:28 AM
Why not use hydraulic steel tube and JIC flare fittings? Cheap, relaible, easy to bend, and pressure rated.
Look in the yellow pages for a hydraulic supply house.
Europa Auto 07-22-2006 08:36 AM
Do you have a picture of the fuel lines you want to replace? I might be able to help you.
126coupe 07-22-2006 09:15 AM
I am not replacing any hard lines only adding one from the rear of the car to the front
RoninLB 07-22-2006 09:38 AM
the fuel inlet and return "hard" lines exit the tunnel in my car with a coupling to rubber lines. I disconnected the 2 rubber line couplings and brought them + hoses to a hose shop. They used the couplings on 2 ss 6AN hoses.
126coupe 07-22-2006 10:05 AM
Does anyone know the id/od for porsche steel fuel lines.
I did a search no luck
Porsche_monkey 07-24-2006 05:46 AM
I believe you need 3/8" supply, 1/4" return.
RoninLB 07-24-2006 11:03 AM
Some wanted info may be these threads
http://forums.pelicanparts.com/porsche-911-technical-forum/267255-68-911-fuel-system.html
http://forums.pelicanparts.com/porsche-911-technical-forum/217825-3-2-carrera-engine-swap-fuel-system-changes.html
Also it may have been member Jim Sims that posted a list of fuel lines ID & OD at one time.
Classic 07-24-2006 02:39 PM
Eastwood sell 5/16 brake line which is a match for the fuel line on my 69
http://www.eastwoodco.com/jump.jsp?itemID=2478&itemType=PRODUCT
DW SD 07-24-2006 03:48 PM
Pressure line is nearly 5/16", which is a common hardline fuel line size. Porsche factory used 8mm OD on many early cars. I revamped my fuel system like this: http://forums.pelicanparts.com/showthread.php?s=&threadid=222204&highlight=earls+ fittings
As you'll see in that thread, 8mm is VERY close to 5/16".
I'd order 5/16" hard line in bulk from Summit. I think you can buy Stainless or mild steel or AL.
Doug
