Can anyone tell me where this wire goes?
So I tore apart my steering wheel to change the turn signal switch, and finally putting it back together. I just can't remember where this wire goes?
http://forums.pelicanparts.com/uploa...1153617226.jpg can anyone help? thanks! |
Replaced turn signal switch. Have same issue with wire shown. Horn contact wire is inside steering wheel.
I checked operation of turn signals, horn, and windshield wipers with this wire not connected. Everything worked. I forget where it goes! |
I think it attaches to one of the srews... I just can't remember which one. Does it matter?
The copper tab gets fastened under one of these bolts, I believe.
http://forums.pelicanparts.com/uploa...1153620988.jpg |
Won is correct--on my Carrera it was connected to the screw on the left green arrow.
I second Won. Just did mine last night.
very cool... thanks guys!
Ground wire (almost all brown wires like that are ground wires). Needs to be grounded (attached) to any metal point in the column...
-Wayne |
| All times are GMT -8. The time now is 02:18 PM. |
