fred cook's Avatar
Cool Aluminum or Iron....Pressure Plate?
I am in the process of gathering bits and pieces for a tranny rebuild and clutch replacement for my SC. For "just a few dollars more" I can replace the stock clutch with the higher performance Sachs clutch assembly with an aluminum pressure plate. Any thoughts on the pros and cons of using the aluminum pp vs the cast iron pp?
Also, need recommendations for an east coast (time, shipping costs, etc.) transmission rebuilder.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-23-2006, 04:53 AM
930turbo's Avatar
I recommend the lighter combination unless the wife has to drive it. The lighter aluminum plate will give snappier response but does require a little more feness to manage. Any time I can knock a pound or two off the total curb weight, I take advantage. I think it's worth it.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 07-23-2006, 05:47 AM
Nine9six's Avatar
I agree. But its not so much the curb weight thats the benefit here, as the reduction in weight of rotating mass which relates to the snappier response.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 07-23-2006, 06:49 AM
Yup...Aluminum is the way to go if you want a more responsive motor.
Get a lightweight flywheel while your in there
Old 07-23-2006, 07:12 AM
I always use the Al pp.
Never used the light weight flywheel due to stalling fears on a 2.7.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-23-2006, 10:42 AM
