Pic of '89 fan with original finish?
Does anyone have a good closeup pic of an '89 fan with original finish in great shape? I want to refinish mine as original but don't have a good original example to match.
Thanks!
John 2005 997 Carrera S -- Artic Silver/Sea Blue Former friends: 1989 930 factory Slantnose / 1998 C4S Coupe / 1973.5 911T / 1976 914 2.0 |
they are magneseum(sp)....no finish to speak of except for the oxidation that occurs over the years....you can polish it...you can paint it....but if you want it to look new...and factory....about all you can do is buy a new one....I painted mine....if you do buy a new one....can i buy yours....a PO messed mine up at the hub and would like to find one cheap to replace it with....
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
Banned
Here is an 89 with 45k miles, I don't know if it has ever been cleaned, I haven't done it.
Banned
yes, I forgot the picture
Used Up User
Here is a jpg scan taken from the original brochure picture.
Even it looks cruddy. But it's hard to tell from the photo . . . Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
3.4 Bigger is better
This is a picture after I bead blasted with very fine glass bead. This is what the original cast finish would be like. It gets dirty very quickly.
This is the fan after sanding and polishing.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
I guess you can surmise from the replies the "original" finish is kind of ugly, hence all the post about fan polishing and painting. One thing for sure is that it needs something. My recipe for the original finish is add one part grease, one part dirt, and age considerably. I've found the best and most durable finish is to clean it well, remove all the residual cosmoline and dirt, and to let it age with a satin, maintenance free, patina. And I have polished my fan like the post above numerous times. The only problem is that it will oxidize quickly, maybe a month, before it turns into a satin finish.
One question, why magnesium?
John
The first picture below is an engine with about 600 miles. It's an 82? SCRS. It's been sprayed with a very thin coat of cosmoline or Tectyll, and has a slight goldish/greenish cast in person. I think they would have done them this way on 89's as well. Joe
Joe Frantz 73 911 T |
I polished and clear powder coated mine. So far it is holding up well with no oxidation (1000 miles). This is what it looks like together. If it doesn't hold up I will strip the clear and PC it silver with a high gloss clear. Magnesium is high strength with very low weight.
89911 that fan looks great. Also sometime soon I will have the same rear bumper due to the pictures of your car, hate that when I see something I like.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport Last edited by 88-diamondblue; 07-23-2006 at 10:51 PM.. |
