OK, so I'm an idiot...
I thought I'd work this out with just more windshield time, but I find that I still frequently leave my turn signal on after a lane change or a shallow turn. I need a louder turn signal flasher. Anyone done this mod? Is there a plug in solution to this, like a louder flasher? Where is the flasher located?
86 3.2 Carrera Cabriolet 99 Ford Explorer Limited V6 ( disgustingly reliable) support vehicle/work truck 2000 BMW Z3 ( gone and forgotten...I got bored) |
The flasher is located under the front hood on the drivers side. It'll will sort of be tucked away around where the hood strut is.
I agree that its very quiet. I did think about doing this when i just got my car but got used to it. You can either experiment with other flasher cans, or you can relocate it to closer to the cabin. Up to you.
_____________________ '73 RSR Interpretation ---------------------------------- |
Non Compos Mentis
When changing lanes, I just hold the flasher stalk part way for a couple seconds, enough to signal, not enough to "click" the signal on. When I let go, the signal stops.
