working around body tags? Is removal Ok---- Where to buy A+B post vinyl?
Just wondering I have to replace the vinyl on the A-post (drivers side windshield post) is it possible to remove the VIN# tag with no damage? Its the only way I can see to replace the vinyl.
Also the PAINT CODE tag on the drivers hinge post
and the VIN# tag on the front latch panel of my 73 I wanna remove them to paint the car properly.....Is this standard process?
TIA
Old 07-24-2006, 05:55 PM
Any painters have any suggestion's
Old 07-25-2006, 07:36 AM
Vin-barrett's Avatar
subscribed-
need to do this as well-
-Vinny
1983 911SC
Old 07-25-2006, 07:53 AM
I drilled out the A-pillar rivets (they are aluminum) and bought new matching rivets from mcmaster. Pelican sells replacement vinyl.
I dont know what to do about the paint code tags. My car had a prior respray and they were either sprayed over, poorly masked, or already removed. I went ahead and took them all off since they looked like crap.
Stephen
70 914/6, GT clone, 3.0L
83 911SC, IROC clone, 3.32L, EFI
84 930, 3.5L
Old 07-25-2006, 10:48 AM
Julian
its the same vinyl that we use on our replica RSR / ST seats. i can send you some if you like. Anything else you need ?
BTW-thanks for working with me on the sports seats
dave
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 07-25-2006, 11:15 AM
Originally posted by TRE Cup
Julian
dave
Dave, that works out perfect .... I will send you a email later today.
As for the seats.... I am glad to help you out, I also need parts so it should work out perfect.
Old 07-26-2006, 07:57 AM
Another question, does the dash have to be removed to replace the vinyl?
Old 07-26-2006, 07:58 AM
LakeCleElum's Avatar
Tags - I know a guy that used to carefully put heavy grease on a tag and carefully wipe off the surrounding area with degreaser. After painting over the grease, it would wipe off and it looked like a perfect masking job.....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 07-26-2006, 08:15 AM
pwd72s's Avatar
Herman, replacement door jam tags are available from a dealership with proof of ownership. Alas, it will be black in color, like in the new cars. Not the original silver. I would STRONGLY suggest masking the metal tags. Better to have masking lines than to tamper with VIN's...Heck, I'd probably mask the original door jam sticker as well. It's pretty tough to hide a repaint from a trained eye anyway. It is very illegal to remove or tamper with VIN tags. Read here:
http://www.boss302.com/legal.htm
Old 07-26-2006, 08:27 AM
To do the front post recover properly, you will have to remove the dashpad
1970 911 Targa "ST"
Old 07-26-2006, 08:56 AM
