aluminum trailing arms for early 911
what is the weight savings over steel trailing arms on a '69 911??
If I remember its like 5lbs each.....
Here is an article from Excellence by Sherwood Lee that should answer all of your questions:
http://members.rennlist.org/911pcars/AlloyContrlArms.htm
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
remember that it is partly sprung wt. so it is more effective than it first appears.
you also get stiffer arms.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
