steering shaft beering
Had problems with my 911 steering really hard, almost as if I had a flat. Well, after further review I found that the beering that is right below the steering univeral is completely gone. The beering is held with a rubber ring and then held in place with a clamp. I tried to find it with Pelican but I was not able to find it or sure of the right item. Does anybody know what the item number is that I am looking for?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
I had the same issue with mine a couple of years ago.
PET calls it a "steering shaft bearing". Apparently the version for '77 and beyond is different than the '76 and earlier. The part number it lists, 911 347 041 00, seems to have been superseded by a couple of different part numbers: 901 347 223 03 - "rubber mounting" (and) 911 347 045 00 - "needle bearing" Good luck to you. I simply walked into a local Porsche used parts place here in SoCal called Einmalig, showed them the old part, told them where it came from, and the owner of the place walked out with a good one two minutes later. Cheap too. I'm sure they have more of them. Here's their website: http://einmalig.com/ |
