-   -   Setting up a differential (preload and backlash) DIY? (http://forums.pelicanparts.com/porsche-911-technical-forum/295430-setting-up-differential-preload-backlash-diy.html)
Elombard 07-26-2006 07:53 AM
Check out these instructions for doing it on a Miata.
http://www.miata.net/garage/diff_rr.html
Looks pretty simple, requires $70 or so bucks in tools.
How different is it to do this for a 911 diff?
The reason I ask Is I would like to add an LSD but the labor to have it installed ans set up scared me away.
Thoughts?
Scott Clarke 07-26-2006 08:01 AM
Erik-
As long as you can use your existing ring and pinion it might be manageable. Measuring backlash is relatively easy, as long as you know the pinion is set at the correct depth. Setting the bearing preload shouldn't be too big of a deal either. If you are starting without the confidence that the pinion is where it should be, matters become more complicated, as the tool to check the pinion depth is hard to come by. Some people have dealt with backlash and mesh patterns recently. If you do a search you should find some relevant, recent threads. Sorry I can't remember specific titles.
-Scott
Early_S_Man 07-26-2006 09:10 AM
Erik,
If it is a factory ZF LSD ... it is identical in dimensions to the existing open differential, so it is a direct bolt-in swap with no required changes to the setup. Plastigauge can be used to verify the current clearance during assembly!
defcon65 07-26-2006 11:30 AM
There's a lot of threads on this - Tyson Schmidt has expert advice on this adjustment.
randywebb 07-26-2006 11:33 AM
Scott, can you define "the pinion is where it should be" more?
Scott Clarke 07-26-2006 12:15 PM
Randy-
I mean the fore/aft position of the pinion along the long axis of the car. This is the measurement that requires the special, expensive tool. Without the tool, a protracted series of trial and error trial installations are required (unless you are really lucky).
Elombard 07-27-2006 04:00 AM
Thanks Guys I will have to do some searches, I had not seen it come up.
