Tranny mount question. Please input
Has anyone replace the rubber tranny mount on both end of the tranny cross bar? This is a 911 1978. Holding the bar on hands, I think the rubber mounts are press in there. Anyone know if they can be press out and new mount can be pressed in using hand press tool?
Thanks. |
There is no mount available for the G50 as a replacement. I also believe the new part is NLA. You G50 folks need to get on Hayden and Tyson and try to convince them there is a need for a WEVO G50 trans mount!
Cheers |
huh? no replacement available? Meaning I can only drive my car for only couple more months?
Do you mean no after market part right? How about normal stock part? Don't tell me none at all. I'll go and rip it off from someone else cars :lol: I searched Pelicanpart and found this came up. Doesn't look like the mount on my car at all. Can it be used? http://www.pelicanparts.com/cgi-bin/...e/wvoSSmt2.jpg |
That will not fit, it is for the 915. To the best of my knowledge there is NO aftermarket mount and the factory one is now NLA as in you can't get one! Not sure why, but I searched up and down a couple of months ago for one for a customer and came up empty!
Cheers |
Still can't get it. So all of the G50 car will be out if the tranny mount is ripped? arghhh. There must be a solution out there.
Anyone anyone? Can the older bar/mounts go in G50 tranny? It looks the same. |
| All times are GMT -8. The time now is 04:38 PM. |
