| Registered Join Date: Dec 2003 Location: Phoenix
				Performance increase from a lighter flywheel?
			I will have my engine apart soon enough.  Replacing a piston & cylinder on my Euro 1983 SC.  Engine has 3.2 JE pistons, 21/20 (20/21) cam, stock CIS injection, headers, dansk sport muffler, etc.  Still in the process of diagnosing the problem, but that will all get worked out as well. I have thought about adding carbs and changing the cam again; however, will not be able to pass emissions in Arizona. So I am going to keep it the same as it is right now...Unless it is going to need a full rebuild. If that is the case, I will get a 3.6 and go from there. I was wondering if there are recommendations for a light weight flywheel, and what performance gains one should expect? Or is it even worth the investment? Thanks, | ||
|  07-10-2006, 08:57 PM |
| Registered Join Date: Nov 2004 Location: Greater Metropolitan Nimrod, Oregun
			They are fun.  There is no performance gain except that you have lost some wt. from the car and can more easily rev the motor.
				__________________ "A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off | ||
|  07-10-2006, 09:03 PM |
| Registered Join Date: Feb 2003 Location: Black Rock, CT
			Well, there are no measurable gains on an engine dyno, but the lowered rotating mass does help the engine spin up faster, and that can equate to faster shifts, better downshifts, and better acceleration.  It is slight though, and the better setups, like WEVOs', aren't cheap, so the gains aren't good "value".
				__________________ Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] | ||
|  07-10-2006, 09:14 PM |
			I would think the revs would be easier both up and down.  Besides the money, are there any downsides to going with a lighter flywheel?
|  07-10-2006, 09:21 PM |
| Somewhere in the Midwest Join Date: Oct 2001 Location: In the barn!
			You're best off just getting an aluminum pressure plate (versus the cast iron PP) if you don't already have it.
|  07-10-2006, 09:26 PM |
| Registered Join Date: Jun 2004 Location: Rio Rancho, New Mexico
			There is a very good article regarding light weight flywheels at  UUC Motorwerks.com. Look into the flywheels. Bottom line, there is a reason that every performance oriented motor sport routinely uses light flywheels. It is part of reducing weight of the entire rotating mass in the powerplant. These folks pay big money for these upgrades. Now is it something you want for a typical street engine? Maybe, maybe not. Read the article, "How light weight flywheels work"
				__________________ DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red | ||
|  07-10-2006, 09:48 PM |
| Back in the saddle again Join Date: Oct 2001 Location: Central TX west of Houston
			I'd be surprised if a slight difference didn't show on a dyno.  Some of the engine power must be used to spin the reciprocating mass, if the reciprocating mass is reduced then that power is free to accelerate the vehicle.
				__________________ Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa  SOLD 2004 - gone but not forgotten | ||
|  07-11-2006, 05:33 AM |
| GFCC Join Date: Apr 2002 Location: Phoenix, AZ
			"I will get a 3.6 and go from there." Great, just when I had talked myself out of throwing money at suspension upgrades. I'm going out to the garage right now to cut my shock towers, DA$NIT. .3 seconds.
				__________________ Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current | ||
|  07-11-2006, 06:39 AM |
| Registered |
			Yes.  But... A flywheel is not an energy consumer -- it is an energy storage device. Car manufacturers (including Porsche) actually do apply some thought to the flywheel weight, and once again it's not as simple as "lighter is better". True: - A lighter flywheel will allow an engine to spin up faster when disengaged from the transaxle. So sitting in your driveway and blipping the throttle, your engine will spin up faster. - A lighter flywheel will allow an engine to spin down faster, so when you shift (up or down) the engine will adjust to the transmission speed faster. - Under straight acceleration, a car with a lighter flywheel will accelerate faster since less energy is required to accelerate the flywheel. If this is improvement is even measureable is debateable. But... - A car with a heavier flywheel will be easier to start from idle. Why? Because the flywheel will have developed inertia while spinning that will help to keep the car from stalling when you release the clutch at low revs. In the absence of an adequate flywheel, you'll need to rev the motor more and slip the clutch more which will shorten clutch life. - A heavier flywheel will tend to absorb driveline vibrations from the engine before they get to the transaxle. So cars with lightweight flywheels will tend to have noisier gearboxes, and potentially a shorter gearbox life. So... While race cars (often light-weight cars, or at least lightened compared to street cars) often use lightweight flywheels, they also tend to have fewer starts from idle, and more frequent rebuilds. These factors will skew the compromise towards using lightweight flywheels. Street cars on the other often start from idle at slow speeds, and are rarely rebuilt -- which swings the compromise back to using the stock flywheel.
				__________________ John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 07-11-2006 at 06:56 AM.. | ||
|  07-11-2006, 06:53 AM |
| Registered | Quote:
 You might want to re-read this. Quote:
   Don't reciprocating masses .. reciprocate, as in move back and forth while rotating masses spin? I think that a flywheel is a rotating mass, while pistons and rods (at least the small ends) reciprocate.
				__________________ John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman | ||
|  07-11-2006, 07:00 AM |
| Registered |
			I know a LWF is one of the best bangs for the buck you can do on a 993.  But that's also because the stock dual-mass flywheel is crazy heavily, problem-prone and expensive to replace.
				__________________ 2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS | ||
|  07-11-2006, 07:17 AM |
			The car is used on the street only to drive to the track and the occasional blast to the grocery store.  Not used regularly as a daily driver.   Living in Arizona, with the AC removed, no sunroof and only windows to roll down, makes for an uncomfortably warm ride. Yesterday was around 112. Plus with the 9.3:1 compression pistons, when the ambient temperature get above 85 or so, I only use race gas. Too expensive to use on the street on a regular basis. What I am trying to say is that the car is pretty much a dedicated track car. I understand that the intention is not to tear it down every weekend (race team) and keep the maintenance to a proactive but not overwhelming level. Are there any testimonials about SC's or Carrera with a lighten flywheel. I appreciate Rick Lee's 993 comments, but that might be apples and oranges. Thanks for all the replies. | ||
|  07-11-2006, 07:37 AM |
| Registered Join Date: Dec 2005 Location: In a race car somewhere...
			I had a Patrick Motorsports LWF on my Targa and it was a great upgrade. The engine will response will definitely improve. i would do it.
				__________________ brant giere 2005 996 cup 1991 964 euro cup (Larbre #28- race 1987 carrera 3.2-street/de car 1962 Austin Healey 3000 | ||
|  07-11-2006, 07:45 AM |
| Senior Member Join Date: Feb 2000 Location: Lacey, WA. USA
			With all due respect to John's comments, I think Mike should continue to discuss and consider using a LWF.  Sure, it stores less interia and therefore is more challenging to drive from a full stop, but there are substantial benefits. On the track, Mike will need to spool his engine up and down many times. If this engine spools more quickly both up and down, shifts are quicker. This saves time and keeps power on the road. Also, the energy savings, even when the car is moving and in gear and the clutch pedal is not depressed, is substantial. Perhaps not hugely different from the stock setup, but substantial nonetheless. At 6000 rpm, the engine is turning 100 times per second. If the flywheel's circumference is two feet, then its outer edge travels at 200 fps. A gram turning in a two foot diameter circle at 200 fps is effectively "heavy."
				__________________ Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" | ||
|  07-11-2006, 08:28 AM |
| Registered Join Date: Jul 2000 Location: So. Calif.
			In the future, it would help provide more succinct answers to understand the intended purpose of the modification. Track use can tolerate more compromises than a street-based car. For track use, yes, install a light flywheel. No stop lights (usually) on the track. Sherwood | ||
|  07-11-2006, 10:23 AM |
| Wider is Better |
			Assuming that you reduce your flywheel weight 10%, if the engine torque remains the same, the angular acceleration of your flywheel will increase about 11%.  The real number will be less than this due to internal engine friction changing at higher acceleration rates, and by the time this increase in flywheel acceleration filters to the ground through the transaxle, wheel bearings, etc, I think your overall gain will be pretty small.   My experience with street cars with light flywheels was that they were ridiculously easy to stall when starting out. And what really concerns me is that the 11% increase in angular acceleration mentioned above will be most apparent when you miss a shift and the engine exceeds safe RPM's 10% quicker.
				__________________ Wider is Better | ||
|  07-11-2006, 11:03 AM |
| Registered |
			I've got a light flywheel and PP in my 930, but since I haven't driven with them I can't comment. I replaced the 27lb stock flywheel on my 78 280Z with an 11lb HKS flywheel and I think it was the best upgrade I ever did. And I upgraded everything on the car. You may stall leaving a light once or twice at first and maybe later if you're not thinking about it, but for the other 99% of the time I think you'll enjoy it. It'll make the biggest difference in 1st and 2nd gear, after that it feels about the same.
				__________________ 2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) | ||
|  07-11-2006, 11:15 AM |
| Registered Join Date: Dec 2002 Location: bay area
			I've got one on my street car. Yes the engine spins up faster but it also spins down faster when changing gears which, once you get use to it, is not a problem. No troubles with stalling after the innitial akward stage, I'd say a day or so. Yes, it transmits more vibration which I suspect is one of the reasons Porsche didn't include them in their street cars, feels less refined. Overall, it makes the car a little more entertaining to drive. Certainly more fun but not a night and day difference in acceleration. I enjoy it but try to drive a car with one if you can. I don't think you'll disslike it I just don't know if it will be enough of a transformation given the money you'll spend. Obveously, the best time to do it is when the tranny is out of the car to minimise the cost. | ||
|  07-11-2006, 12:41 PM |
| Registered |
			I have a LWF in my 96 C4S and it does rev faster.  After driving other 993's, I feel it is also quicker than the equivalent stock 993. But my question is if acceleration is a function of automobile weight and torque. Would not moving up the torque curve quicker with the LWF allow the car to utilize a higher torque value faster, making the car quicker? Granted it's the exact same curve LWF or not, but how quick the engine can move up that curve should translate to faster acceleration. My buttmeter seems to think that's the case. I've heard the argument about less inertia and that is true, but my thought is how quickly you can apply the torque would be the biggest benefit. On the negative side, I do have some rattle at idle and the car does idle a bit lower. Some 993's have a problem with stalling with the LWF but I think that's primarily in the OBD 1 cars (1995). | ||
|  07-11-2006, 02:33 PM |
			I still am undecided... Seems like a clear cut 50/50 on what I should do. Patrick Motor sports is located in my city, perhaps I should inquire with them? Anyone use a Patrick Motor sports products? - Track car 95% of the time - Engine is apart for repairs - Ez installation of the part Still undecided. If you were in the same situation, would you consider it or would you go ahead and make it happen? Thanks for the replies. | ||
|  07-11-2006, 10:13 PM |
