-   -   smog bypass (http://forums.pelicanparts.com/porsche-911-technical-forum/29572-smog-bypass.html)
77911s 02-10-2000 05:12 AM
smog bypass
Is there a way to bypass all that smog stuff on my 77? there is the pump/injectors and egr to contend with...what's the best way to get rid of it?
thanks
G
77911s
C Metzger 02-10-2000 01:15 PM
Hey 77 911S,
My 76 911S came with all the emmissions stuff removed when I bought the car in Oct,99. The p.o. had simply cut the air injector lines and crimped them. The smog pump itself is no where to be found. As far as the reactors are concerned, your best bet is to go back to the 74 style exhaust system. I'm not sure where you live, but don't throw those components away. You never know when you might need to appease an emmissions inspector. I'm not 100% sure about the e.g.r. valve, but no doubt someone will let you know soon enough. By the way, I removed the crimped lines to the air injectors, and plugged them with bolts. I guess however, that Roy at MotorMeister can hook you up with some cool little plugs that look more professional.
