Al S's Avatar
How to eek out a bit more rear camber?
I just put some fat rubber on my 83SC, and need a tad more camber on the rear due to minor fender rub.
The max camber I could achieve is 1.3 deg.
Any tricks on how to get another 0.5 deg, short of machining another eccentric with greater offset?
Gratuitous pic attached
Thx
Al S
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 08-09-2006, 10:56 PM
PRO Motorsports
Tyson Schmidt's Avatar
Sometimes the toe eccentric interferes with the full range of camber. Try removing the toe eccentrics, adjusting the camber, then reinstall the toe eccentrics and adjust the toe.
What happens sometimes, is the toe eccentric is in the oblong side down position, and fouls the opening in the arm, preventing full camber movement.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-09-2006, 11:28 PM
911-32's Avatar
What Tyson said.
You should be able to get a lot more than 1.3 degrees at that ride height. Its normally the front where it is hard to find camber.
Old 08-10-2006, 01:34 AM
I believe Elephant Racing has a product that allows you to run more negative camber on the rear as well IIRC. You may want to check them out or perhaps Chuck will chime in here.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 08-10-2006, 05:28 AM
I modified my eccentric bolt to be "more eccentric" by slightly undercutting the eccentric portion with a die-grinder and welding the other side. It only took about 5 minutes.
ED
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 08-10-2006, 07:57 AM
Chuck Moreland's Avatar
Rear CamberMax
available from our host:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSprf_pg30.htm#item29
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-10-2006, 08:26 AM
