-   -   Easy way to set odometer to 000000?? - not stock vehicle (http://forums.pelicanparts.com/porsche-911-technical-forum/295844-easy-way-set-odometer-000000-not-stock-vehicle.html)
DW SD 07-28-2006 12:39 PM
Is there an easy way to set the odometer to zero? I just installed a rebuilt engine and am interested in aligning the odometer with the engine. The odometer is not stock to the vehicle, so nothing is in synch.
Or do I need to send to North Hollywood or PA speedo?
Doug
rouxroux 07-28-2006 12:59 PM
Go to the top of this page, click "Tech Info Center" then search for gauge repair, scroll down until you get to the "odometer repair" section. Best of luck with youor project.
Wayne 962 07-28-2006 01:07 PM
Right, what he said. Also documented in 101 Projects for your Porsche 911...
-Wayne
