Horsepower estimates
Want to see what some of you guys who have done the EFI conversion think my hp will be at. Im going to be running the EFI conversion kit goingsuperfast.com sells. Im using 83 lb injectors with dta pro8 ecu. Im going to stay with single plug and stock manifold for now. I will be running his intercooler along with a SFR GT35R turbo, headers, zork tube, msd ignition, 10mm magnecor wires, methanol injection, gt evo cams, 11o octane (does that matter?) and 1.2 bar of boost. Hoping I can be in the 400 horsepower range. I will go with twin plugs and carrera manifold in the near future. Thanks guys
nevermind I will be using carrera heads and intake manifold.
I have:
Tec3 EFI, carrera heads and intake manifold, twin plug, 964s cams, 1.0 bar boost, IA-HFS turbo, Kokeln IC, and GHL headers. I got 400/400 to the wheels on pump 93 gas. With your methanol, larger injectors, different turbo, larger boost, who knows. I would guess 500 at the wheels?
Kirk Crashed: Silver 1992 Turbo S2 Sold: '86 930 minor mods; '94 3.6 Turbo; '85 Euro 930 (3.2 Intake, Tec3r EFI, TwinPlug, Garrett Turbo, JE 8.1 Pistons, 505 rwhp) |
I would guess 500 hundred as well
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
add the twin plugs to my list
No extra power but nice safety factor. Most people I spoke with said it is completely unneccessary on turbos. I still added them because the heads I got were already drilled for them and the EFI system was twin plug capable as well. Plus extra safety (even if unnecccessary) is a good thing.
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
No grenades here I hope. I did go with twin plug, whether it was neccessary or not.
I would also guess closer to 500 at the wheels.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I would twin plug a turbo engine for the additional margin of safety = my guess for your engine would be 470-490. Should be alot of fun!
Mikey930, let us know when you get some results. I am considering methonal injection as well and would like to see someone else running a similar (not exact) setup.
Im going to do dyno runs with and without the methanol. I will post dyno results by next friday.
Cool, thanks in advance.
Me like track days
1.2 bar.........buena suerte, my friend.
Experience - WAY more than I care for - tells me solidly that 1.2 is insane. Even with EFI. Stop at 1 bar. For track work.......forget about it. I can help you recycle the aluminum bits and pick up rings with a magnet.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
craig, thats why I run methanol, it allows for more boost and timing, but I do beleive your right. I would hate myself if I blew the engine up after all the work. I will probably stop it at 1 bar.
Me like track days
Do yourself a HUGE favor and read these:
Friend's: http://forums.rennlist.com/rennforums/showthread.php?t=80793 Mine: http://forums.rennlist.com/rennforums/showthread.php?t=282438 Take an hour, learn from our mistakes -
thanks alot
Automotive Monomaniac
I would also stop at 1 bar.
The engine will love you much longer...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Me like track days
You'll be BEYOND HAPPY at 1 bar with EFI - or even at .8 bar for that matter.
Who is doing the work and tuning?
Jon at black forest racing in pineville, nc
