-   -   Help - A New K&N Question ??? (http://forums.pelicanparts.com/porsche-911-technical-forum/29600-help-new-k-n-question.html)
rboylan 02-15-2000 09:10 AM
My early 911 has Weber 40IDA3C carbs and I need to replace the air cleaners. If not K&N, then what should I use as replacement filters? The car has watershields and I need to know what I can replace the K&N's with? Specific help would be appreciated. Thank you.
Rich
Early_S_Man 02-15-2000 10:06 AM
I don't have a definitive answer for you, just a couple of 'hints' from possible other cars using the 3-bbl Webers. European readers/viewers may have a better idea or familiarity, as it is my understanding that Fiat/Ferrari Dinos used the same carb on the V6 Dino engine, as did the Apline-Renault A310 V6, so whatever type of air cleaner assembly they used might still be available, and possibly paper elements may have a common Fram or other replacement.
Warren Hall
1973 911S Targa
Va914 09-22-2005 08:37 AM
Old but what the heck
Anyone BTDTSmileWavy
RoninLB 09-22-2005 09:47 AM
Sherwood uses foam filters.
911pcars 09-22-2005 04:08 PM
Yes I do. However you may not wish to go through the trouble.
Last time I researched, there are no off-the-shelf automotive filters, paper or otherwise, that fit the K&N sillouette. In my case, not wanting to go with K&Ns, I took some generic Amsoil foam air filters, cut them up height and lengthwise, and reglued the ends to the correct circumference. They fit around a metal screen support. Works fine so far.
MM was selling K&N-sized foam filters through ebay for awhile; not sure what happened since their site doesn't list them. They had several colors (yellow, red, blue).
I got this link from another thread today which contained these heavy equipment air filters made by "Stoddard" (not the Porsche guys).
http://www.globaltecheng.com/ProductCart/pc/viewPrd.asp?idcategory=80&idproduct=4358
I don't remember the exact K&N dimensions, but except for the height (5"), these look close to fiitting.
Let us know what you find out.
Sherwood
