exhaust stud question
I am installing a set of SSI's and during removal of the exhaust nuts 10 studs came out. I am in the process of replacing them and was curious about the proper method of installation (I have looked in all of my books and can't find it anywhere.) What torque value should they be tightened to?
Thanks in advance. Darin B |
the stud in the head are we talking about?/ I always use locitite 271 for install on those with a straught edge 6 inch rule to determine depth of the others and the one you are replacing
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Thanks Ben. Good idea.
1995 993 - Black/black, RS splitters, brake ducts 1978 SC - "Toyo Spec" - Completed |
no problem
Re: exhaust stud question
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Re: Re: exhaust stud question
If there is a lottery in Portland, go buy yourself a ticket!
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
LOL.....That's what I hear.
Darin,
The exhaust port gets way too hot for Loctite to be effective ... since it wil melt the first time you fire up the engine, so don't bother! Double nuts on the new stud ... 'snug' is good enough, probably 10 -12 lb-ft. If you are using factory exhaust studs with two separate threaded sections, the shorter section goes in the head... it will bottom out.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I just did the same thing. Replaced several studs. I used silver anti-seize compound. Stuff is supposedly good to 1800F. If it's good enough for aviation spark plugs it should be good enough for automotive exhaust studs.
I'm curious about this too. I just replaced all my exhaust studs and coated the new ones with Permatex anti-seize. Frankly, I am more concerned with getting them out in the future than keeping them in in the present. Don't the torqued fasteners on the heat exchangers keep the studs from backing out on their own?
MAGA
I "Never-Siezed" mine also. I really do not think it matters whether you put them in dry or not. My hope was that if they ever had to come out again, that maybe they would rotate out as opposed to snapping off.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Amen to that!!!!!
