Fan Corrosion
What causes this - and whats the best way to clean it up?
My aim is to powdercoat the fan but would like to know if I need a new one or can rescue this one. Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. |
Tim,
As long as it is not cracked, it can be cleaned up with a metal friendly media blasting and either powder coated, zinc plated, or maybe even anodized.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Salt or mineral rich air will accelerate corrosion.
Ben
1986 3.2 Carrera |
Junior Member
Fan clean up
I polished my fan while on the car this weekend. Used WD40 and steel wool to start with. Keep at it until the metal starts to look clean and shiny. If you want to take it further to a mirror like finish, you will have to use fine grit sand paper, cutting wax, and jewelers rouge / fine metal polish. A polished fan will transform your engine bay.
Cheers |
I polished mine with Mother's alum/mag polish, took a long time and was never really 100% perfect, but nice.
One visit to the car wash to clean up a messy banjo oil fitting area and it stained already. One touch of water and poof! Polished: After the carwash: ![]() I should of just painted the sucker silver.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
glass bead then clear coat in a rattle can works well. I just glass beaded mine and painted it red. Still looks nice
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
