H-5 headlights
Hi,
My 87 coupe has the factory H-5 headlights. I notice that there are several upgraded bulbs available, but that many sources recommend upgrading to H-4’s. What’s the storey?
If I go the upgrade to H-4’s do I replace the entire unit or just the lens/reflector unit?
Thanks,
Old 08-03-2006, 07:22 PM
buttjoint's Avatar
You have to replace the whole unit, the trim rings and the plugs that the lights plug into
Old 08-03-2006, 07:28 PM
Bill Verburg's Avatar
Also when using higher wattage bulbe you should activate the headlights w/ a relay, the column switch you save could be yours.
Bill Verburg
Old 08-04-2006, 05:52 AM
All this is posted many times in the archives of these posts....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-04-2006, 06:19 AM
Used Up User
imcarthur's Avatar
As Will said, do a search & you will be reading for a week.
The basics:
Your headlights should be on a relay or relays regardless of what you do.
H5s can be cleaned to improve them, but . . .
Higher bulbs in H5s will probably melt the socket & wiring.
The H4 Upgrade requires completely new headlights but done right will give you all the light you may need.
Ian
'87 Carrera Cab
Old 08-04-2006, 06:29 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Keep the H5's and install relays to protect the stalk switch. I swapped out the useless fogs for Hella 450 driving lights which turns night into day.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 08-04-2006, 07:56 AM
