71 rear suspension fit on an 84 chassis?
I may need to move an 84 tub and currently have my 71 911T suspension available. Will this work? I am thinking the front should bolt right up, not so sure about the steel control arm type rear setup from the early car.
Yes, it will bolt up ... though the anti-roll bar won't attach - linkage is different.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Great...I was also thinking there was some other dimensional difference with the pre-72 cars, couldn't put my finger on it.
If I remember back that far, the angle of the rear shock mounting was a little different as well.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
Rear shocks for a 69-71 will also be needed because the lower shock mount is different. The toe and camber eccentrics are also different (shorter). IMHO, you should supply full disclosure to the new buyer that the '84 has parts 13 years older within, but I'm sure that isn't a winning marketing plan. Sherwood |
Thanks to all for the info. |
