Somewhere in the Midwest
Adhesive Removal off Paint?
I jsut can't seem to get some dried adhesive off my car! The adhesive is from contact paper used to tape my numbers on for track events. The last DE I was at was a particular hot day and I have black paint...so the adhesive didn't come off with the vinyl like it usually does. Well, it's been almost a year now, and the adhesive is still there!
I've tried that Orange Gooo. What a waste of money! So what's next? What won't hurt the black paint? |
Wurth Citrus Degreaser....... of course, a German product when all else fails.....
Maybe "Oil-flow" ... a commercial gum/tar remover that dosn't attack paint..... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Use WD-40. Works better than anything else.
Brett |
goo gone, diesel fuel is good also. takes a second to loosen it up and then it slides right off.
I've used the aerosol decal/bumper sticker removal stuff from Autozone with good results. It even works so so on dried tree sap but requires multiple applications.
Steve B 1972 911T 1999 328is
Steve B. 1972 911t 1999 328is |
I'm tempted to just pour gasoline on the damn paint at this point. That Goo Gone type stuff just foams up and when I wash it off, the adhesive is still THERE! It's like laugh and pointing at me...
I've even tried some of the spray stuff sold at the FLAPS.. I'll look for some of that Wurth stuff. Have you used it Wil? On harden/dried sticker adhesive? |
At your local professional automotive refinishing store:
http://products3.3m.com/catalog/us/en001/auto_marine_aero/automotive_aftermarket/node_GSSPN37QHGgs/root_GST1T4S9TCgv/vroot_GSLPLPKL4Xge/bgel_GSXXHHTMDNbl/gvel_WWR6DCKBSPgl/theme_us_aad_3_0/command_AbcPageHandler/output_html
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Cool! The warnings in the MSDS are good enough for me. It ought to eat through the stuff. Thanks Warren! I think I saw some of that stuff at the Farm and Fleet. (I don't know why the farmers would need it to remove adhesive from their tractors....
MAGA
Souk, I have used a rubber type adhesive remover disk chucked up in a
variable speed drill to "rub" off adhesive from car paint. It slightly dulls the finish, but a quick pass with some swirl remover shines it right back up. They sell these disks at auto paint supply stores. It just rubs the stuff right off instead of spreading it around as solvents typically do. I wish I had bought one before I removed my stone gaurds when repainting my 951. I must have gone thru a whole roll of paper towels, a bunch of mineral spirits and a few hours of cursing and rubbing.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Souk,
Farmers can get pretty picky about that new green and yellow paint on their restored John Deere tractors!
Goof Off or lighter fluid will usually do the trick.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
Avon Skin-So-Soft works well, too.
I used to use it to clean the rubber off the rear quarters of my drag car.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I'd be careful with goof off. 3M adhesive remover got the nasty German carpet adhesive off the back of my tub.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Laquer thinner works well.
Ben
1986 3.2 Carrera |
Retired Member
Try varsol. Rub it on using your fingers so you won't scratch the paint.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
19 years and 17k posts...
Denatured alcohol may work...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
gas on a rag works everytime. thats what most auto detailers use
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Senior Registered User
The first or second post said to use WD40. I have used that product for years to remove stuff from glass jars or anything else that had some form of "sticky" stuck on stuff that I wanted to remove. Very simple, will not mess up the paint to where you have to "rub it out" will not blow up and burn your a55. 3-M remover is geat but it screws up the finish on two coat paint.
Try WD40, the if that does not work ! Sand paper Randy Jones 1971 911 "Iris" |
Many chemicals will dull the paint. What I use that works and seems to do the least damage is paint thinner. The generic stuff from Wal Mart. Laquer thinner is very bad on paint.
-Andy
72 Carrera RS replica, Spec 911 racer |
Laquer thinner is what most body shops will use to remove adhesive. Overspray is always removed with it. It will destroy the paint if you leave it on but a little on a rag and the adhesive will desolve with light rubbing. Wash immediately and re wax when dry.
Ben
1986 3.2 Carrera |
