Very Hard Cold Start
I am having mega trouble co;d starting a 74 CIS.. Otherwise the car runs great. Any ideas?
19 years and 17k posts...
Alot to check here... have you changed anything recently? I just had my ignition/fuel injection system gone over by a Porsche mechanic who knows what he's doing and he found a few things wrong. How comfortable are you with the CIS and the methods for testing the pressures? Do you know the location and proper testing techniques for the cold start valve, warm up regulator, fuel distributor, etc...? Ther's alot to look at, but I would start with the basics (spark? fuel? pressures?) then tray to remove the variables one at a time. Troubleshooting by replacing components willy-nilly will get expensive fast!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
If the '74 is like the 73.5, make sure the micro-switch is activated when you pull the hand throttle all the way up....This provides the extra fuel needed while cranking a cold engine.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Yep, the 73.5 and '74 are "unique" because they both have the throttle microswitch in the circuit that controls the CSV and they both have a throttle control pressure regulator next to the throttle body. Check your wires and hoses and be sure they are all connected. A cracked vacuum hose can also wreak havoc in the cold start scenario.
