-   -   Anyone Ever Put a 911 Engine into a VW Bug? (http://forums.pelicanparts.com/porsche-911-technical-forum/296376-anyone-ever-put-911-engine-into-vw-bug.html)
rdrr 08-02-2006 01:11 AM
In our local Porsche club, one of the owners also has a bug with a VW transporter engine (somewhat tweaked). At a hillclimb event recently he was very quick, i.e faster than most of the Turbos and GT3s!
http://forums.pelicanparts.com/uploa...1154506121.jpg
fastbacker 08-02-2006 11:37 AM
That Ghia looks killer. I couldn't get the link to work though.
ANTONIO 08-02-2006 04:47 PM
Yeah right, you can have one for 300K', cheers, Ant.
dafischer 08-02-2006 06:53 PM
Originally posted by targa911S
I had a 1600 Super engine in a 66 bug. It bolted right up after grinding a bit off the inside of the bell housing. Ran like a scalded cat.
I had a 1600 Super in a 58 beetle. It too ran like a scalded cat. With the stock brakes, it also stopped about as well as a scalded cat would.
Plash 08-26-2016 11:37 AM
Id love to know more about this kg
Its my dream
sixbanger 08-26-2016 03:32 PM
I used to have a single port 67 Ghia. Wished I'd owned it ten years earlier. It was a ball to drive. I'd love to drive that Ghia.
matthewb0051 08-26-2016 05:10 PM
With '58 4 cam engine
http://forums.pelicanparts.com/uploa...1472256614.jpg
matthewb0051 08-26-2016 05:13 PM
with '58 4 cam engine
http://forums.pelicanparts.com/uploa...1472256781.jpg
http://forums.pelicanparts.com/uploa...1472256794.jpg
HarryD 08-26-2016 06:38 PM
Originally Posted by matthewb0051 (Post 9256938)
1958 Porsche Bill Rutan Special. Neat car.
This was on Chasing Classic Cars. Porche Hill Climber | Chasing Classic Cars | Velocity
Actioned at Mecum: https://www.mecum.com/lots/CA0812-134323/1958-porsche-bill-rutan-special/
tcar 08-26-2016 07:09 PM
Originally Posted by rfn026 (Post 2731139)
Paul Newman used to have one up in Connecticut. This was decades ago though.
Richard Newton
Don't think so... I know he put a hopped-up Porsche 356 motor in the back of a VW cab.
He got a surprise the first time he drove it and decided he'd better put 356 brakes on the car also. :)
The 911 (and Corvair - more common) engines in a beetle require extending the bodywork a fair amount.
dafischer 08-26-2016 07:30 PM
I've got an old photo of Bill Rutan siting in the Special at the Mt. Washington Hill Climb. I'll scan and post.
Trackrash 08-26-2016 07:47 PM
How about a 3,2 mounted mid-engine with a 944 trans and rear suspension in a transporter.
This is an amazing build. http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/524564-porsche-powered-mid-engine-double-cab.html
Joe Bob 08-27-2016 05:30 AM
Geez, newbie drags up a 10 year old thread.
OK, I put a 2.2/6 in a 356.....
gumba 08-27-2016 07:02 AM
The 911 bug I read about in the early 80's used a 914 chassis with a 2.7rs motor and a super beetle body cut length wise to fit the chassis. My vision was to use one of the aftermarket tube chassis's that fit the stock body (I had a '57 oval window shell at the time) and use a 911 motor.
I got out of bugs and moved into crewcabs. After reading about Porsche putting 3.2's in the Vanagons (B32) I pursuit that approach. Over the last 14 yrs I've run a few different 911's in my '68 crewcab. Started with a '73E 2.4 carb motor, moved to a stock '86 3.2, then converted that to 46mm pmo's, Electromotive ignition and a few other add ons. A few years ago I got the bright idea to stuff a stock 3.0 turbo motor in there. That morphed into a modded 3.3 with about 400 h.p. I used a stock '73 trans with the 2.4, a '84 trans with a 7:31 and short 5th with the 3.2. The trans was rebuilt and beefed up, and the 7:31 replaced with a 8:31 by Wevo. Fun stuff!
With the dramatic price rise of Porsche parts, the days of 911's into VW's is pretty much over.
RichardNew 08-27-2016 07:59 AM
http://forums.pelicanparts.com/uploa...1472309671.jpg
This is probably the ultimate sleeper. The transmission is from a 911, spyder brakes are at all corners, the engine is the 1700cc 547/5 flat four (same as the Elva Porsche). The fenders, door skins, engine lid, front trunk lid, running boards and bumpers
are all aluminum. They were done by Troutman and Barnes.
http://forums.pelicanparts.com/uploa...1472309875.jpg
The car is a part of the Collier Collection in Naples FL
Richard Newton
Historical Racing Images
kennethg 08-27-2016 02:58 PM
I remember seeing a video on the Ghia flying down the Autobahn. There was an article in VW World I think. I have it and could dig it out of a box. Tonnes of hours in it for the rear subframe and suspension carrier. Killer build tho.
https://www.youtube.com/watch?v=swuXiAiZrdA
86 911 Targa 08-27-2016 03:14 PM
Paul Newman.
As I recall the actor Paul Newman was "tooling" around
Malibu in a green Porsche powered bug.
Gerry
Trackrash 08-27-2016 07:15 PM
At one point, many years ago, I seriously considered putting a 911 motor in my Baja bug.
Truth is my 2,1l T1 has more power than I ever need in a 1500 lb car. And I don't have an extra 150 lbs hanging off the back, nor do I have to wait to 4 thousand RPM to get any real power.
http://forums.pelicanparts.com/uploa...1472350519.jpg
Frog76S 08-31-2016 02:11 AM
Check out the VW bug with RX-7 engine that appeared on Leno's garage, Aug 1st episode. Apparently, it's a wolf in sheep's clothing and has surprised more than a few sports cars.
https://youtu.be/GO2dpG96-2g
jlex 08-31-2016 04:22 AM
This topic is probably more thoroughly discussed at the VW site: thesamba.com
