-   -   "84 Carrera- project list (http://forums.pelicanparts.com/porsche-911-technical-forum/296490-84-carrera-project-list.html)
sus911 08-01-2006 03:03 PM
These are the projects I have in mind in the coming months:
A/C delete
Heater backdate
My questions are:
Are these easier done at the same time?
I don't give 2 hoots about the A/C but I want to keep the heater and I intend installing SSI's and twin out sport muffler when my exhaust system craps out.
I guess the A/C delete will entail removing the cabin fan but what about the the rear blower and the front windshield fan etc. ?
How does the backdated system work?
Does anyone know where to find the thread on where to start this work.
Thanks Pelicans...........
aigel 08-02-2006 03:16 AM
The A/C removal can be done independantly. I would do that first. You can keep all the fans in place and have them blow warm air then.
The heater back date is best done at the same time than the SSI install, as you are connecting the hoses from the engine fan to the heat exchangers (SSI) and you will likely change some engine tin to get it perfect.
You should do a search on "backdating heat". It will have all the necessary info.
George
