Anyone have a recommendation on how to repair or lessen the severity of the common cracked dash?
The Dash on my 73 911 E has the common crack. Replacing the dash is not an option for me. I would be happy with simply reducing the size / severity of it. I used one of those vinal repair kits once and it kind of worked for a while but seems to have opened up again. suggestions appreciated Chris 73 911 E |
"O"man(are we in trouble)
Get one of those dash carpets. I have one in my car just to protect the dash (no cracks) and I don't even notice anymore, same color as dash. Then when you get the cash go for the new one. Best solution and lesat amount of work.
Use a dash cap. I put one on my car due to cracks and it looks better than new and was less than 5 minutes to install.
Currently own: 1980 911SC slantnose 1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because) 2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD) Gone but missed: 1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade) 1984 Jeep CJ-7 (1994 Chevy Blazer) 1987 Chevy Corvette (1996 Mustang Cobra) 1993 Jeep Wrangler (1995 Mustang GT Conv.) 2003 Ford Explorer Sport Trac (1987 BMW M6) Future: Hopefully not too far off Ferrari Testarossa (Lamboghini Diablo or Countach) Detomaso Pantera |
Any Pics? I did a quick search and found a couple likely sources but they did not have pics (Pelican included). Url's would be helpful.
I don't think the carpet solution will work as the major crack is on the rounded foam that faces the interior (not on top). Thanks Chris |
Not concours, but I used Phenoseal black sealer/caulk. (standard Home Depot item)
Multiple small applications and wipe off any extra with a water moistened lint-less rag. It is not a perfect match but It does look a lot better, and it seems to be holding things together . I left it a bit below the surface just in case I come across a better matching material. Ron 70 911 E targa |
My "Plan B" was to get a dash cap, then apply Alcantra to it. Fortunately Plan A worked out...a new dash.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
A new dash is expensive and I fear it will crack again
Supposedly the new dashes are much more resistant to sun damage (and cracking) due to materials improvement. I can't confirm factually, but perhaps someone can support that point, or debunk it.
'74 Euro Carrera * '64 356SC Coupe |
The Phenoseal black sealer/caulk does it dry up like rubbery feel?
Does that stuff expand? I have cracks as well, seems like a good idea to cover up the cracks......... |
It is a sealer caulk for windows, etc and is a bit "Rubbery". The good thing is it stopped the crack from growing larger.
I was looking for a stop-gap solution for now. The car is fully original and quite nice. Maybe someday I will replace the dash, but you need to pull the windshield, etc. Not in my game plan for now. Best Wishes, Ron Y 70 911 E Targa |
I'm surprised that the kit opened up on you. If the crack is really wide, there is a delux kit that contains material that glues down inside the crack before you add the vinyl/ Try to get the repair as flat and even with the dash as possible. When you are happy with the results, you'll notice that the black repair may not match exactly in color. Get some black vinyl spray paint, mask the dash and spray the entire dash. If the repair was done correctly, the crack should no longer be noticeable.
Now another quick fix would be the vinyl dash caps. I put one on my 71 without gluing it down just because I knew I was going to get a new OEM dash eventually and was tired of looking at that huge crack in the dash. Outside of not being original, it actually is not bad. I had fully installed one on my 944S and sprayed it tan to match my interior and it was hard to notice that it wasn't OEM. My 71 will be ready for paint in about a week, so if you are located in the NJ area you could come down and see it. It's like brand new, but I'll be ordering a new OEM dash shortly. Make me an offer if you're interested, good luck Allan
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." Last edited by Gearbox; 07-31-2006 at 08:57 PM.. |
Mine has several very fine cracks so the window caulk idea would not work, also the '88 has a diff. vent arrangement.
Bill W. '97 Arena Red / Gray 993 Cab '93 968 Coupe 6 Spd '88 911 Cab Red/Blk (sold) |
Has anyone tried one of these or is this what Gearbox is using? Pelican sells the carpet pads and that's not what I'm looking for.
PS found your dash cap for the 88 on ebay under 86 87 88 89 90 91 / 98 Porsche 911 930 NEW Dash Pad Cap
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." Last edited by Gearbox; 08-02-2006 at 08:25 AM.. |
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." |
