Leland Pate
Guest
Posts: n/a
**Weatherstripping HELP!!**
Hi everyone, As I speak I am trying to install new Vent window, outer window (squeegie), and inner felt seals on my SC Targa.
On my last post on this topic Brian said that he just pryed up the outer anodized door window trim. I looked at it and before I do it I just wanted to ask again. . . You just pry it up?
And does anyone know any short cuts for taking out the fixed vent window? Do I still need to remove both of the frame sections?
It is going to take me a while to get everything preped and remove the door panels. My computer is no more than 10 foot from the car so I will be checking in regularly to see if anyone had any suggestions.
Thanks, Lee
Old 02-23-2000, 02:31 PM
Leland Pate
Guest
Posts: n/a
OK. . . I got everything in on the drivers side. The vent window seal gave me a bit of grief but a little bit of silicone grease made it slide in much easier.
And the outer trim did POP right off like Brian said. It gave me a chance to clean and inspect under the metal as well. The outer bristle brush seal thingie (sits under squeegie) was a bit of a pain. I used a screw driver to pop the clips into the holes.
While I have the door panels off. I would like to grease the window regulator rails. What kind of grease should I use?
Thanks, Lee
Old 02-23-2000, 04:20 PM
Leland Pate
Guest
Posts: n/a
I'm done. . .
LOL
Looks alot better too. . .
Old 02-23-2000, 08:22 PM
