drag racing the short bus
dd74's Avatar
Can cracks in the rear PORSCHE reflector be repaired?
Possibly from putting down the engine lid too vigorously (not in anger, mind you) and just all around age and bumping over poor L.A. roads, have left a nice vertical crack in the center of my rear reflector. So the question is can cracks be repaired on the reflectors, or am I simply SOL?
Sorry, no camera available, so no pics.
The Terror of Tiny Town
Old 09-25-2006, 03:13 PM
Zeke's Avatar
If you can pry it open a bit, use model cement, you kow, the kind you used to use on plastic kits. Has a lot of tolulene in it which desolves the plastic and fuses it together. So, the cement is not really a glue. I think you would have to have the part laid flat and very carefully tape off nearby. Since it fuses the plastic, the joint can be polished. Never done this, just speculating.
Old 09-25-2006, 04:06 PM
RFR RFR is offline
RFR's Avatar
I have done this on lenses. it works and if done right creates an ivisible repair.
sand the cracked area with 1000 grit wet sandpaper and buff.
looks great.
Roman in LA
78 targa
Old 09-25-2006, 04:50 PM
84porsche's Avatar
Send a message via Yahoo to 84porsche
I used SuperGlue for my rear tail lights and it worked flawlessly except for my fingers getting stuck together for awhile. What have you got to lose, try it, if it doesn't work, you are no worse off.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 09-25-2006, 05:18 PM
