Cleaning cv joints and ball cage & hub
Is brake clean spray and a brass brush sufficient to clean the old lubricant off the ball hub and cage?
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
I used paint thinner, a toothbrush, lots of paper towels to get the gunk off, then brake clean for a final clean.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
You won't need a brush ... just Brakleen & paper towels. Wipe off the majority of the old grease with paper towels, first. When just a film or coating is left ... spray Brakleen on paper towel and wipe down ball bearings and cages. It will take multiple paper towels to clean thoroughly. Continue using paper towels wet with Brakleen spray to wipe off beearing or cage until no black is transferred to the paper towel.
You have seen pics of what damaged ball bearings look like with pitting or black/blue discoloration, right?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 08-02-2006 at 11:04 AM.. |
brake clean will work fine. To get the cv joint completley clean you need to remove it from the half shaft. There is a c clip that holds it on. Once off, take a good look at how it is put together because it will fall apart easily. This is actaully a good thing because it is easier to clean. I just did mine and i used paper towels to get the bulk of the old grease off then clean with brake clean (I used Oil Eater from Costco, Great stuff). Clean 1 at a time so you can use the others as a guide for re-assembly.
They are tricky and frustrating. especially when one or more of the balls fly out and roll away. Check your boots while you are in there. Good luck, Rich
1976 911/S/SC/BASTARD Mid9 Member #12 |
Here are a couple of very good articles with pics:
http://volksweb.relitech.com/cvjoints.htm http://www.type2.com/bartnik/cvjoints.htm Here are a couple of good Pelican threads on the subject of CV-joint assembly/disassembly: CV joint disassembly The trouble with DIY projects.... the CV nightmare
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thank you.
Back in New England!
It is very important to put the joint back together the exact way it was originally. Each ball must be placed into same place it came out of. There is zero tolerance for error and if you make one, there are great chances that the joint will fail.
I also recommend wearing rubber or surgical gloves. Have fun with it! -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
I've heard the above & have also heard other experts say it doesn't matter...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
ps: I've read NOT to use compressed air to blow/clean out the cv joint.... |
Wow! I have never seen so much grease in my life. It just wouldn't go away.
