-   -   It is finally running...kinda (http://forums.pelicanparts.com/porsche-911-technical-forum/296810-finally-running-kinda.html)
por73911 08-03-2006 10:57 AM
OK I replaced the FD and the cars started right up. I finished up some of the details and decided it was time to take it out for a spin. I went 1.7 miles and lost power, it starts and idles but would not move itself. I let it sit for an hour and went back started it and it drove home with low power. I am thinking fuel filter? Any other ideas? I have noticed that when I "blip" the throttle that is does not seem to rev very high (2500 rpms). I have to slowly push the throttle down to slowly rev.
Paul
Rot 911 08-03-2006 11:02 AM
Sure sounds like fuel starvation.
por73911 08-03-2006 12:37 PM
It is starving for fuel, I can push the throttle and put my hand in the air box and the flap is pulled way up but there is no change in rpms...any thoughts?
por73911 08-03-2006 12:38 PM
Kurt, that is 911 thumbnail is the same color as my car!
cmcfaul 08-03-2006 12:42 PM
screen at the bottom gas tank was gummed up and used to cause me the same issue.
Took out the gas level sensor and poked a hole in the screen. 5 years later...no problem.
Chris
73 911 E
por73911 08-03-2006 12:52 PM
I will check that tonight, thanks.
