84 carrera warm hesitation
hi guys,. My 84 carrera continues to hesitate when warm. When cold its fine. driving me bonkers. Ive checked the standard things plugs, cap, Ive even had it to the dealer, thats not saying much though. they could not isolate the problem. any help is appreciated
2006 mini cooper s, w/ all johncooper options( ex wife got it)1984 alfa(Alfa heaven)1964 mini cooper s(awaiting restoration)1984 carrera (still have her) 90 dodge 4 wheel truck, 200,000 miles that 318 keeps going and going( threw a rod putting in a long block) 2006 chrysler 300 srt-8, berrian sand rail twin turbo vortec v6 |
forgot to mention it has 75,000 miles AND not driven very much maybe about 1000 miles per year. hope you guys can help. Im pretty good with automobelia, this problem has me stumped big time
2006 mini cooper s, w/ all johncooper options( ex wife got it)1984 alfa(Alfa heaven)1964 mini cooper s(awaiting restoration)1984 carrera (still have her) 90 dodge 4 wheel truck, 200,000 miles that 318 keeps going and going( threw a rod putting in a long block) 2006 chrysler 300 srt-8, berrian sand rail twin turbo vortec v6 Last edited by rob6; 08-04-2006 at 12:44 AM.. |
Have you had the mixture checked?
Also, don't bother with a dealership. They're useless when it comes to the older air-cooled cars. Find a good independent shop in your area.
1984 Targa |
I just went through this with my '84 and I can tell you that it worked fantastic for me. I had a bit of hesitation from 2k to 3k rpms and I did the adjustment outlined at the following site and it is an amazing transformation. Others have decribed better tip-in (also experienced) and more responsive pedal (here also). It only takes 15-20 minutes to pull the AFM, a half hour to carefully remove the black box lid, and ten minutes to do the adjust and replace everything. Piece of cake - and the best part? It is 100% free! Good luck,
http://frwilk.com/944dme/afm.htm
Dan “Out on some Sonoma County road, with Jimmy Dean and Steve McQueen” 1984 Carrera Targa |
It sounds like the problem is fuel delivery or a bad temp sensor maybe. The easiest thing to do is go to your Porsche dealer, buy a can of BG and dump it into a full tank of premium. It'll clean out the injectors and fuel lines. I'd change the fuel filter before doing this. Then go through all of the tests and checks outlined in the Bentley manual.
