I will be doing my first DE next month and I think my front brake pads need to be replaced I'm checking them this weekend. If they need replacement what pad do you guys recommend for street and occasional AX + DE and that our host sells? Car is a 83SC with stock rotors and calipers. Thanks
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Brake pads.....
RFuerst911sc,
If you are doing your first DE/AX, stock brake pads (Pagid) will be fine. Brake pads less than 50% of original thickness are recommended for replacement. Your stock set up will be OK and not worry too much. Enjoy your first DE/AX and have FUN. Tony |
Platinum Member
For first event I would use stock pads. Be sure to flush the sysem with new brake fluid.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Hawk HP pads are another good option. Some folks like ATE Blue brake fluid as well. There are better fluids available, but the ATE stuff works well and is relatively cheap.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
I've had great luck with Motul, but only satisfactory luck with ATE blue. The blue is fine for the street and a light track day, but no comparison with the Motul. You shouldn't lose your brakes at an autocross though - they don't get used enough. FWIW I use the pagid street pads, and they hold up fine on the track and behave normally on the street. Have fun, be careful
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Now in 993 land ...
Metal master are stock type pads and they are sold here and cheap. They will get used up quick, but your rotors stay nice! I used these for a long tme. They are okay, if you don't mind the dust.
I bleed brakes before every track event. Get a power bleeder and get used to the routine. It is a good idea to take all four wheels off before a track event and carefully inspect the suspension and brakes anyway. Also, if you replace the brake fluid, it may be a good time to go with DOT steel braided hoses, if your rubber hoses are old. (more than 5 years old). George |
Southern Class & Sass
Good advice so far. Especially on running a good, fresh, barke fluid. As for pads, if you have over 50% of your pads left, you'll be fine for your first DE. But if you need to replace them, I'd recommenmd Hawk HP+ pads all around.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Thanks guys. My suspension is up to snuff as it has been rebuilt recently with new bushings,torsion bars and sways but the brake lines are still the rubber ones and I'll visually inspect them this weekend. I do own a Motive power bleeder and have been useing the ATE blue fluid. I replaced the front rotors 2 years ago ( 7K miles since ) along with the pads ( Mintex ) and full fluid flush so I'm due at least for another flush. I'll check the rears also. This is my 1st DE do you guys have a pre-race inspection done by your mechanic as a precaution? Is it a requirement? Just don't want to miss anything obvious as Sebrings walls don't look too forgiving!!
PCA isn't very active with HPDEs in Honolulu. However, I run the BMWCCA HPDEs and all cars must be teched prior to the event. Go in there with an open mind and remember to breathe.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Check with your registrar for the event. Usually there is a Tech Inspection form that will need to be completed by a shop (usually one authorized by the club for DE's) and there is also usually a medical form that asks for basic medical/emergency info.
Tony G 2000 Boxster S |
I did this a couple of weekends ago after a lot of research, here are my choices:
Porterfield R4-S pads - do all four, not just the front for lots of reasons. Stop-Tech - SS brake lines, great pieces. ATE blue fluid Bed the pads using the method on the Stop-Tech website. It all went on smoothly and works great.
Scott _____________ 1984 Carrera Targa 1999 MB E 430 Sport 2006 Chevy Tahoe |
MBruns for President
If you are doing sebring - then I am going to recommend a real track pad - like either the hawk blues or porterfield r4. I am also going to recommend motul 600. Flush your brakes a few days (not weeks) before the event. Lots of humidity in florida - and since the brake fluid absorbs water - the closer to the event that you can flush your brakes, the better off you will be.
Sebring is a great learning track, there's plenty of run offs, it's wide and fast. It also can eat your brakes at an alarming rate and there is nothing quite like going into the hairpin and having your brake pedal go all the way to the floor. It tends to curb the learning process.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Be prepared to get hopelessly hooked and then start asking questions like the one I asked here:
Brake Fade
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
Now in 993 land ...
I disagree with Jeremy. For a first track event, you will not need race pads. You will be fairly slow and getting maximum breaking power is not the goal.
As far as tech goes, the club running the event will have clear rules. Some clubs have you self tech, others want a shop to look it over. George |
The way to go is to buy the new GT3 RS, I'm sure the stock brakes will be just fine.
I hear the green ones are the fastest! Otherwise, stock pad should be OK for your first event (unless you are an ex F1 driver). For later, I would stay away from the ATE blue stuff (this is what I'm using right now) go directly to the motul 600 (this what i will do soon). I had good results with Hawk HP+, but my track (Tremblant, Qc, Canada) is easy on brakes
Walter 79 Euro 3.6 911SC: Track machine 06 Magnum RT: Family and winter drifting machine 81 BMW R100RS Cafe Racer: Bicycle machine |
Somewhere in the Midwest
Ferodo DS2500 or PF97 pads. Rick's car is set up pretty nicely. If it's a long day...and he learns quickly, he might start to run out of brakes if the current pads are not new. The DS2500 or PF97's make for a good street pad too, so there'll be no need to swap them out after the track day.
It's not much fun comeing home metal on metal. Been there, done that, got the t-shirt.
And yes to all you doubters - I ran out of brakes after the 2nd session on the 1st day. Carrera brakes are bigger than SC brakes, yes, driving styles will differ, your results may vary.
Pretty sure these were metal masters. From now on, you can refer to me as Nigel Mansell, check that - Sir Nigel Mansell.
Me like track days
My 2 cents - (I am a Pagid dealer - for 3 1/2 yrs):
*Carrera brakes have thicker rotors (and a wider spread caliper of course) for more heat capacity, otherwise they are identical brakes & pads *Sebring, hot weather, 1st time? Better have that fresh fluid - it is a MUST. I'd really recommend track pads...the streets will wear exceedingly quickly. I have found Metalmasters are decent for 1st timers.....but it depends. Above all, be certain they are nearly full thickness. Many people have had horrible experiences with Hawk. PF is a nice pad, Pagids are the top dog....and expensive. Me? I'd use Pagid Oranges, ATE or Motul, look the entire car over yourself and get an inspection.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I did these before my first track day based on Souk's nod. They are very good compared to stock. A little squeaky around town, but very good overall. My first DE was at Sears Point and I barely even wore them down at all. Can you say S-L-O-W newbie driver?? ![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
