I have to wait about 2-3 minutes before taking off, otherwise the car will stall. Is that normal?
And after a cold start, my oil level gauge is always in the red until it warms up. After running it for about 5 minutes, the needle rises to normal readings. I assumed this was normal until the oil warmed up. Please tell me if this is not normal. Perhaps need more oil? Thanks, Darrell |
The mixture is extremely rich on a cold start. This extra gas tends to wash the oil off the cylinder walls and accelerate wear. The idea is to get the engine up to temp as quickly as possible to avoid this, so drive off right after startup, but keep the load on the engine and the RPM's down until you've warmed up. The owner's manual advises of the correct procedure to accomplish this. Idling for an extended period is a no no.
ianc Edited to say: Nashvillecab, with a Motronic or CIS car, you should not have to wait 2-3 minutes to drive off without stalling. You have a problem. |
I've done both - the car has idled for a few minutes, and I've also taken of as soon as the key was turned. Neither process has shown an effect on the engine, other than smogging out the neighbor with a putrid rich mixture.
I do think keeping the engine rather conservative at low temps is prudent. However, I've also been in cars with skilled Porsche mechanics who could care less if the car's been sitting awhile; they stomped on it the moment they were in second gear. |
ianc |
Kemo provided an interesting link in an earlier thread shown below:
http://forums.pelicanparts.com/porsche-911-technical-forum/294171-slick-50-a.html?highlight=acid A portion of the link from The Engine Oil Bible that Kemo included in his reply: Quote:
