-   -   What's the trick to aligning the engine lid latch? (http://forums.pelicanparts.com/porsche-911-technical-forum/297031-whats-trick-aligning-engine-lid-latch.html)
rs6er 08-04-2006 01:43 PM
Put a new cable in. Didn't want it so loose I wouldn't be able to unlatch it, but I can't get the latch to close and hold the lid down.
randywebb 08-04-2006 02:09 PM
search will find some info here, but also see if you can fidn the Pano article called Secrets of Lids and Latches - reprinted in an Up Fixin'
rs6er 08-04-2006 02:44 PM
I have 25 years of Panos. Any idea when it was from. I already did a search. Most were about getting it open— not closing it.
Hugh R 08-04-2006 03:09 PM
Put masking tape across the hole and push the plunger through the tape, repeat as necessary.
randywebb 08-04-2006 03:48 PM
no idea when but it's pretty old - see if there is an index anywhere on the 'net?
JP911 08-04-2006 03:53 PM
One precautionary step would be to remove the decklid grill so that you'd have a chance of opening the lid should it become stuck. Of course, that assumes that you don't have an air conditioning condenser in place.
rs6er 08-04-2006 04:11 PM
I did find an old post which explained what I needed. Alligning was not what I needed. When I installed the new cable, I didn't have it so the catch was sticking out in the lower hole. After adjusting that, I was pretty sure it would work, but just in case I did what JP911 suggested. This was also suggested in the thread where I found my answer. Now I'm tempted to just remove the rear condensor altogether. I'm afraid to though, as I don't know if there's any R12 left in the system.
imcarthur 08-04-2006 04:52 PM
Here's the article:
From Up-Fixin VI
http://forums.pelicanparts.com/uploa...1154735445.jpg
I've been wondering too, since both my front & back lids are slightly out of whack, but I've been afraid to screw with them.
What was that other post?
Ian
rs6er 08-04-2006 05:10 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=216679&highlight=engine +latch
