Mike the mechanic
Guest
Posts: n/a
915 to G-50 swap info
Hi, i am seriously considering swapping my tranny in my 86 Carrera for a G-50. I rebuilt my transmission due to worn synchros and bearings but i still don't feel comfortable with the shifting feel. I know that I would have to change my pedal assembly for the hydraulic clutch, but what else? Will my C.V. joints bolt up? Do I also have to change the shifter and linkage? How about the mounnting points? I know the bellhousing has to be shortened but is this something any machine shop can do, or is it mmore involved? I would really love to have the shifter feeling like my 325is!! I am pretty sure I would have to get an 87 or newer clutch kit but do I also have to get a matchinng flywheel?
Thanks to anyone in advance who can answer this very long list of questions.
Mike
Old 02-27-2000, 09:32 AM
Early_S_Man
Guest
Posts: n/a
Before you give up on that 915 read the following threads:
http://www.pelicanparts.com/ultimate/Forum3/HTML/001026.html
http://www.pelicanparts.com/ultimate/Forum3/HTML/001015.html
I suggest one gear oil change with Castrol Hypoy, then a switch to SWEPCO 201 gear oil ... if you haven't already tried it!
Warren Hall
1973 911S Targa
Old 02-27-2000, 12:22 PM
Mike the mechanic
Guest
Posts: n/a
Ok Warren, thanks for the advice, I'll give it a try and let you know!
Mike
Old 02-27-2000, 08:33 PM
Pazz
Guest
Posts: n/a
You might try Patrick Motor Sports http://www.patrickmotorsports.com/ they specilize in g50 conversions & 3.6L conversions & sell kits for the doityourselfer.
Pazz
79 SC TARGA
Old 02-28-2000, 06:08 AM
