LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
What's the trick to aligning the engine lid latch?
Put a new cable in. Didn't want it so loose I wouldn't be able to unlatch it, but I can't get the latch to close and hold the lid down.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 08-04-2006, 01:43 PM
randywebb's Avatar
search will find some info here, but also see if you can fidn the Pano article called Secrets of Lids and Latches - reprinted in an Up Fixin'
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-04-2006, 02:09 PM
rs6er's Avatar
I have 25 years of Panos. Any idea when it was from. I already did a search. Most were about getting it open— not closing it.
John
Old 08-04-2006, 02:44 PM
Detached Member
Hugh R's Avatar
Put masking tape across the hole and push the plunger through the tape, repeat as necessary.
Hugh
Old 08-04-2006, 03:09 PM
randywebb's Avatar
no idea when but it's pretty old - see if there is an index anywhere on the 'net?
Old 08-04-2006, 03:48 PM
One precautionary step would be to remove the decklid grill so that you'd have a chance of opening the lid should it become stuck. Of course, that assumes that you don't have an air conditioning condenser in place.
Old 08-04-2006, 03:53 PM
rs6er's Avatar
I did find an old post which explained what I needed. Alligning was not what I needed. When I installed the new cable, I didn't have it so the catch was sticking out in the lower hole. After adjusting that, I was pretty sure it would work, but just in case I did what JP911 suggested. This was also suggested in the thread where I found my answer. Now I'm tempted to just remove the rear condensor altogether. I'm afraid to though, as I don't know if there's any R12 left in the system.
John
Old 08-04-2006, 04:11 PM
Used Up User
imcarthur's Avatar
Here's the article:
From Up-Fixin VI
I've been wondering too, since both my front & back lids are slightly out of whack, but I've been afraid to screw with them.
What was that other post?
Ian
'87 Carrera Cab
Old 08-04-2006, 04:52 PM
rs6er's Avatar
Rear Lid keeps popping up. Any advice?
John
Old 08-04-2006, 05:10 PM
