Doug Thomas
Guest
Posts: n/a
weber jets
Anyone know what size jets to use for weber 40IDA's on a 77 2.7L?
Thanks for your help.
Old 02-15-2000, 06:43 PM
Roy
Guest
Posts: n/a
32mm Venturies
135mm Mains
180 Airs
55 Idles
F-26 Tubes
for normal use
What ignition do you have and how are you feeding the carbs??
Roy at http://www.motormeister.com
Old 02-21-2000, 09:11 AM
Doug Thomas
Guest
Posts: n/a
Thanks for your reply Roy,
I am converting a 77 2.7 w/CIS to webers. I still have the original ignition but I believe I will have to go to a recurved dist. Is this correct? Also I do not have a pump for the carbs. Do you know the best pump to use? Another question. I obtained some manifolds with the carbs(I believe from a 2.2L), can I use these on my engine?
As you can see I'm in the early stages of the conversion and I need all the help I can get.
Thanks again.
Old 02-22-2000, 02:21 AM
jbirkett
Guest
Posts: n/a
Doug, if you haven't already purchased the carbs, Roy at MM has a complete kit that will give you everything you need right down to the hose clamps. I am considering the kit to replace MFI on my '72T.
John Birkett
73'T Targa
Old 02-29-2000, 09:34 PM
