scott matre
Guest
Posts: n/a
Oil press guage
I have an oil pressure guage that dances wildly at idle. Once moving on up in the R's, it pegs at 5 bar and stays. Once it comes lower than 5 though, it looks like hummingbird wings. Anybody have thoughts whether It would be the sending unit or the guage??
Old 03-01-2000, 07:28 PM
Early_S_Man
Guest
Posts: n/a
Sounds like a bad/dying sender unit, or a loose/corroded connection some where ... the gauge will peg if you disconnect the sender, or if it goes 'open' internally.
Warren Hall
1973 911S Targa
Old 03-01-2000, 07:41 PM
ewr1
Guest
Posts: n/a
I have this same problem with my 1988 Carrera Targa...it jumps at idle from 2 - 4 but stays steady at high rpms. I know the oil level is ok so I live with it...
Old 03-05-2000, 07:12 PM
Early_S_Man
Guest
Posts: n/a
If you guys want to test the gauge and decide whether it is the sender or not check this earlier thread for a test produre:
http://www.pelicanparts.com/ultimate/Forum3/HTML/000718.html
Warren Hall
1973 911S Targa
Old 03-06-2000, 09:56 AM
