one of gods prototypes
bell's Avatar
an overhaul.....engine drop......full interior....etc
i've been putting off tearing into my 911 for a few months, mainly was due to lack of garage space.
but problem solved, a few weeks ago i moved into my new house with a 2 car garage for my 911.
plus i have unlimited room for my fish tanks (a 700-800 gallon tank is in the "design" phase).
today i put it on jackstands and started rolling, seats are out, most of the audio is out, everything is unhooked for the engine/tranny drop (except oil/fuel lines), will be dropping it saturday.
once it's out the tranny will be cleaned up and taken to ed baus for a rebuild, the engine will go onto a borrowed engine stand/yolk (thanks christian ).
i'm not sure how far into the engine i'm going to go.....a full inspection will tell me that later, expect most all oil seals replaced, the use of christians exhaust stud removal tool ("a quiet boom"), valve adjust, and a thorough cleaning....plus more "while you're in there" i'm sure......
plus suspension.....replacing all bushings front/rear, 22/28 t-bars (ron's in hershey looking for them for me), i have bilstien sports for the front, need to buy the rears, caliper rebuilds f/r, a custom front "skidplate" to protect the fuel tank/front pan (going a little lower than normal).......etc....
christian is going to stop by tomorrow to assist with the drop, my first drop so a second set of eyes/hands never hurts
and i forgot to take some pics.....i'll take plenty tomorrow.
Brought to you by Carl's Jr.
Old 04-21-2006, 06:24 PM
Nickatnyt's Avatar
so is the car down for the spring/summer driving season?
1982 SC...Guards Red + Linen
Old 04-21-2006, 06:33 PM
bell's Avatar
it'll be on the road within a month
amazing what can be accomplished when you have the space......all the things i listed above that i've done so far happened in about an hour.....
Old 04-21-2006, 06:37 PM
bell's Avatar
engine/tranny is out
i was suprised how simple it was......i love these cars
thank to christian (a quiet boom) for stopping by and lending an experienced hand
here is the obligatory pic
more to come
Old 04-22-2006, 04:32 PM
bell's Avatar
tranny was taken to ed today, we pulled it apart for the rebuild......
first gear was missing a bunch of dog teeth, and the sleeve looks like it needs replaced, i'll have more details once it get broken down and evaluated more, but there is no play in the shafts, the diif looks good etc. so nothing catastrophic
here is the one pic i took
Old 04-23-2006, 02:58 PM
bell's Avatar
pulled the intake manifold off tonite......there is some oil leakage into the runners......looks like valve seals.
i noticed that on pelican there are oversized valve seals available, are they for larger valves? or can something else wear?
here are some pics down the runners.....in the order of cylinder 1-6
Old 04-23-2006, 07:17 PM
bell's Avatar
also found one of my fan deflectors laying on top of #2, i'm pulling all the tins....looks like the bolts disappeared.
Old 04-23-2006, 07:18 PM
Bell,
You're pertty ambitious. Good luck with getting all that done in a month. I've been working on mine for a long time and still have quite a ways to go. I hope things go smoothly for you. Make sure to show us some new pictures.
Marv Evans
'69 911E
Old 04-23-2006, 09:14 PM
bell's Avatar
as long as i don't have to get too far into the engine i should move right along, i went from having a single car garage with a gravel floor to a 2 car with concrete.......it's amazing what can be accomplished when there is space to move around
Old 04-23-2006, 09:41 PM
bigchillcar's Avatar
gotta get that man out of the engine bay..gotta be costing you some major horsies..
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 04-23-2006, 09:54 PM
bell's Avatar
i was experimenting with some fred flintstone power......
Old 04-24-2006, 07:34 AM
gotta beat today's gas prices..
Old 04-24-2006, 09:41 AM
Bell,
Nice work. In the first pic, is that a rotted hole in your driver side heat exchanger? Nice time for SSI's??
John Adams
1980 ROW 911SC
Old 04-24-2006, 09:53 AM
bell's Avatar
ssi's are out of budget right now, if my tranny didn't need rebuilt i'd have them already
my heat exchangers are a little tired, but the exhaust pipes are solid, i'll be cleaning these up as good as possible once they are separated from the engine.
there are a few pieces of engine tin which need patched/replaced, i'm going to sand it all down and paint.....probably black, but haven't decided if i want it a color yet.
Old 04-24-2006, 11:29 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Bell - Sounds ambitious - good luck. I just dropped my 914 motor last week for the first time (my latest project) and have most of it sealed up. It had some major oil leaks. Hoping to reinstall next week. May have to get Graber to assist - he owes me!
Cheers
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 04-24-2006, 12:04 PM
bell's Avatar
shoot me an email when you're ready, if i'm avail i'll head up
looks like i need to replace the drivers side rear engine tin, pretty rotted, the 2 bolts which hold it to #3 cylinder are a problem....one snapped and the other is rounded.
also the bolts were wasted where the tin bolts to each other, that's an easy fix though.
there's alot of grim in the cylinder fins.....they'll be getting a thorough cleansing......i need to make some blockoffs to seal the intake ports tomorrow, this will keep crap from falling inside......it's going to be a messy job
Old 04-24-2006, 01:59 PM
bell's Avatar
mannnnn...........these exhaust studs are a *****!!
they are all pretty much welded to the studs, tried heating them til they were glowing but to no avail......the 12mm nuts i cut off carefully, no big deal, however the barrel allen nuts which get accessed through the heat exchanger holes are a total big pain in the arse. they were rusted enough where it's bigger than 8mm, so i tried grinding down a larger allen to fit tight.....lots of heat.....nothing. won't even break so i can drill them out.
so i move onto cutting them, took about an hour for #1, #4 i'm halfway through.....the 2 middles are broken flush with the he's, i have no idea how to get the rear ones out as my dremel won't fit anywhere near them........
Old 04-26-2006, 06:15 PM
Do you have the engine on a stand? If not, working on the exhaust is alot easier when the motor is flipped upside down on a stand.
Old 04-26-2006, 06:58 PM
bell's Avatar
yep, on a stand and upside down......
Old 04-26-2006, 08:17 PM
A Quiet Boom's Avatar
How did I miss this thread?
Anyway bell's made some great progress. We drilled and replaced all the exhaust studs. I CNC'd some port block off plates so he could thoroughly clean the engine. The trans is back and looks fantastic. I assume I'll be getting a call soon to help put it back in. (either that or I'll go over and put it back together myself LOL) Oh, I was able to salvage the heat exchangers for him as well, ugly welding but they're solid now.
bell! get your car done already we need to go for a drive!
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 07-05-2006, 12:05 AM
