Boxster ECU
Anyone know where the ECU is located on a 98 Boxster?
76 911S 82 911SC Targa (Hot Rod In The Making) |
I think the DME/ECU is under one of the seats, though I do recall that there is some sort of computer on the front wall of the back trunk, underneath the carpeting.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
Bye, Bye.
I believe it is under the driver's seat.
Elvis has left the building. |
anyone with 100% surety about that?
you should probably post your question on the Boxster Haven forum if you haven't already....there are couple of really sharp Boxster guys over there:
http://forums.pelicanparts.com/boxster-cayman-forum/
Matt M. -- Go Irish! 1990 964 C2 Targa "Cheap tools and no experience has taken its toll" - J.W. Ghosts of the Past: '77 911S Targa 3.2 Conversion, '89 Carrera Coupe, '99 Boxster, '70 911T Coupe ,'80 911SC Targa, '77.5 924 |
Bye, Bye.
Found this old thread where Dave from Pelican said the ECU was by the battery. Therefore, I must be wrong.
The DME Control Module is located in the rear trunk, left front.
Bob "FUD" Mainely Custom by Design 65 356C (Outlaw) 76 912E 2000 Boxster |
What would be the chances of just replacing the ecu to make a fresh water flood boxster run again?
