checking timing on a Carrera
Since my car has some miles on it (117,000) I would like to check the timing of the car.
I know once its set the computer does the rest, but how do you check it to see if it is set right?
Is there an article or a link someone can direct me too. I tried a search but that isn't going well.
greg
My car is a MFI system.
1986 944 Turbo - Guards Red
Old 08-07-2006, 12:14 PM
Friend of Warren
You can check it with a timing light. Just can't change it.
Kurt V
Old 08-07-2006, 12:20 PM
Oh, I thought it was like a Ford or Chevy, where you can turn the distributor left or right to set the advance or retard it.
So its just goes in one way then I assume?
Old 08-07-2006, 12:21 PM
Friend of Warren
Oh no, you can screw it up three ways from Sunday. The end of the distributor shaft is a gear. The distributor will go in any number of ways. It will only go in one way correctly and have the engine run.
Kurt V
Old 08-07-2006, 12:37 PM
Somewhere in the Midwest
MotoSook's Avatar
The distributor gear is not straight (it's helical), so when you drop the distributor into the hole you have to rotate the rotor a little counter clockwise. The gear will rotate the rotor to the number-1 mark.
Old 08-07-2006, 12:45 PM
