What is "good" flow on a 3.2 injector
The car in question, an 87 Carrera with just 13,000 miles from new (!!), had sat almost continuously for four years, and would not run. After a few tests on other components, we felt that the injectors should be checked, so we removed them, and sent them to a "rebuilding" service.
Marren Fuel Injection reports 4 of 6 in a set had poor spray pattern, all had flows of approximately 73 cc/min. They were all "dirty" on the "reverse cycle." (What does "reverse cycle" mean.) Marren returned them "clean" with good spray patterns and 82 cc/min. Will this fix the car? I can't know until later this week, when I get time to re-install them. Does anyone here understand the significance of these numbers? |
I very recently had my injectors cleaned. Car has 54k miles.
After cleaning they were all matched at: 103cc per 30 sec at static 2 bar 53cc per 30 sec at 50% duty cycle 2 bar 68cc per 30 sec at 50% duty cycle 3 bar. A little more info on the test conditions relating to your figures might help the comparison. |
I had some 3.2 injectors cleaned by Marren a few years ago. They sat on the shelf a few months before I assembled the engine. One went bad sitting on the shelf. I ended up buying 6 new ones.
I just talked to a shop owner yesterday and he had the exact same thing happen to him this spring (3.2 injector + Marren = bad injector). Injectors are expensive but I'm not sold on "rebuilt" injectors. -Chris |
I had sketchy performance from my car a couple of years ago when I was still in Stuttgart. It just wasn't as peppy as it once was. I feared the worse, although I was just looking for an excuse to do a 3.6 swap.
I took it to Ruf and they recommended new injectors. They say new injectors every 130,000km or so. At 130,000 miles, I was abviously past that. I took their recommendation (got them online from our host vice paying 180 Euro each locally... ouch) and they made a significant difference. The compression and leakdown numbers ended up being great. The new injectors were worth every penny. |
| All times are GMT -8. The time now is 03:33 PM. |
