teal911's Avatar
Porsche Crest fuel pump issue
hi everyone,
on my 80 targa, I noticed that the fuel pump does not turn on when I turn the key, I always assumed that the fuel pump always cycle and then shuts off to build pressure in the system. My other car a 70 mercedes 250 ce (with EFI) does, maybe the CIS in the porsche does not have to?
The car runs OK, with some hot start problems, but that is another issue.....
Thank-you so much!
Old 08-09-2006, 03:49 PM
sudo apt-get purge 930
equality72521's Avatar
The fuel pump doesn't run until you start cranking. There is a contact on the fuel distributer that controls the circuit to the fuel pump. It doesn't allow the pump to run unless there is air flow past the plate.
--clutch-monkey
Old 08-09-2006, 05:38 PM
ruf-porsche's Avatar
It depends on the car. On my the fuel pump does come on when I turn the key to run before start. I been told that this is incorrect, but since owning this Porsche for the past 6 years I have never had a hot start or cold start problem,
Old 08-09-2006, 07:06 PM
teal911's Avatar
thank-you
it seems to me kind of odd that the fuel pump does not run when turning the key, I would think that having fuel circulating would improve starting the engine...uhmmmm
Old 08-09-2006, 08:59 PM
tbitz's Avatar
EFI pressurizes the fuel rails and then turns the pump off if the engine has not started.
In CIS the fuel pump should only come on when the engine is drawing air (cranking or running). This is a safety feature, in the event you roll the car and a fuel line breaks the pump isn't spraying fuel everywhere.
In CIS the accumulator is used to hold pressure from the last time the engine ran to aid in the next start.
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 08-09-2006, 09:32 PM
teal911's Avatar
Thank-you tbitz!!!
your site is VERY interesting.....!
80 SC targa Teal
78 Lancia montecarlo Teal (in Italy)
70 euro Mercedes 250 CE Blue met.
05 Lexus 470 GX White
Old 08-09-2006, 09:35 PM
It's a safety feature to avoid flowing gas when the engine is not running. For various reasons, too many of the early CIS system cars had non-running engines filled with the gasoline to the point it was running out the tail pipe. Hot start problems can sometimes be traced to a leaking pump check valve or a bad accumulator. Instead of fixing the actual problem, the air flow switch connector was pulled allowing the fuel pump to prerun and repressurize a leaky system.
Old 08-09-2006, 09:38 PM
teal911's Avatar
Thank-you jim,
if by check valve you mean the one way valve connected to the output of the pump, I had to remove it because after replacing 2 pumps, I realized that that little insignificant item (to me) was bad and had caused the pump failures.
The Pierburg pump that I purchased has a "free flow valve", so I installed it without it.
I do not know if the car had the troubles starting hot before as I purchased the car not running at a very low price.......
80 SC targa Teal
Old 08-09-2006, 10:12 PM
