NE Ohio 911's Avatar
Spacer Rear-Wheel Wobble
I just put 15 mm spacers on the rear wheel. They are the type that bolt down on the existing studs. Now the rear wheel has a bad wobble. Could I have cranked the spacer down too much impacting the wheel bearing?
Old 08-08-2006, 06:07 PM
Had the same problem.
Check that the nuts that hold the spacer are not touching the back side of your wheels. If you have this problem and you have Fuchs wheels or aluminum wheels you will notice that theres is a gouge where the nut is touching the wheel.
I had this same problem with 15x8 fuchs wheels . The 16 inch wheels have a space which allows the nut to clear and does not touch the wheel. I solved it by grinding the wheel where there was the interference.
Old 08-08-2006, 06:15 PM
I have 16 inch whells and the passenger side is fine.
Doug
1984 Carrera Coupe
Old 08-08-2006, 06:18 PM
Oh Haha's Avatar
Nice call, donporfi.
I was responding to him in another thread aboout his camber.
Pacific Blue
Wayne
Old 08-08-2006, 06:19 PM
Is the spacer hubcentric because if not you may get a high speed wobble and need hubcentric spacers.
Currently own:
1980 911SC slantnose
1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because)
2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD)
Gone but missed:
1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade)
1984 Jeep CJ-7 (1994 Chevy Blazer)
1987 Chevy Corvette (1996 Mustang Cobra)
1993 Jeep Wrangler (1995 Mustang GT Conv.)
2003 Ford Explorer Sport Trac (1987 BMW M6)
Future: Hopefully not too far off
Ferrari Testarossa (Lamboghini Diablo or Countach)
Detomaso Pantera
Old 08-08-2006, 06:24 PM
