rfuerst911sc's Avatar
Question where do you buy car numbers? Porsche DE
Well next month I do my first DE and there is a requirement for my car to have numbers on the exterior. They have to be minimum of 6 inch on the doors and 4 inch on the rear. I'm thinking magnetic but where do you buy these? The # 12 is what I'm going to use. I didn't see any from our host.
Old 08-21-2006, 04:54 PM
cali74's Avatar
You might try calling Pelican to see if they can get them even if they aren't on the site.
Also,looks like Rennline has them:
http://rennline.com/product.php/sid/5/aid/28/auto/Porsche/prodid/25
Additionally, try
http://www.nbdgraphics.com/
I think it's a Pelicanite who does No Bad Days Graphics :-)
74 911 with '95 3.6l
Old 08-21-2006, 05:10 PM
<insert witty title here>
Christien's Avatar
Probably depends on your region, but UCR allows you to print them on your home printer and tape it inside the rear windows, so long as they meet the height requirements and it's black ink on white paper. They also allow electrical tape on your doors (won't hurt the paint) unless of course your car is black
If you definitely need/want magnetic, look in the yellow pages for sign makers. They'll do them up for you. IIRC mine were about $30 for a pair. But you'll need to tape them to your car - these are meant for pizza delivery guys, not a Porsche whipping around the track at 100 miles an hour!
Even some well-equipped print/copy shops can do them.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 08-21-2006, 05:38 PM
ruf-porsche's Avatar
Most sign company can make you a set.
Old 08-21-2006, 05:52 PM
abit off center
cgarr's Avatar
I cut out my own from a white magnet sheet
______________________
Craig
G2Performance
Old 08-21-2006, 05:56 PM
MBruns for President
JeremyD's Avatar
Good info here
Poor Man's DE/TT Car Numbers
Old 08-21-2006, 07:38 PM
ipapilot's Avatar
In the automotive section at walmart they sell window chalk you can use for this. They also have a clear spray for the front end to help minimize rock chips. Painters tape works well for that also. If you really need vinyl, check your local vinyl sign shops and they can make them for you in whatever size, font, and color you could want.
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 08-21-2006, 08:17 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Try Office Depot for the giant magnetic door sign set. Print your own numbers on sticky paper and stick them to the magnetic sheet. I cut the magnetic sheets into ovals, and printed black numbers.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 08-21-2006, 08:20 PM
Better in Person
juanbenae's Avatar
or get the sheet stuff like rick mentions and go to a motorcycle shop, they have big stick on #'s pretty cheap. do a search for internet magnetic sheeting, cheapest way to go. the sign companies will jab you for the sheeting
Old 08-21-2006, 09:12 PM
Zink Racer
racers tape
Jerry
983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4
Old 08-21-2006, 10:33 PM
Southern Class & Sass
Dixie's Avatar
Buy a roll of low or medium stick shelf paper. Use your PC to print numbers as templates. All you need then is a razor and a kitchen cutting board.
It works out to something like 50 numbers for four dollars.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 08-22-2006, 04:36 AM
GeorgeM's Avatar
Solotime does nice work.
Also EuroPDR
Be careful with magnetic. I have ovals with 8 inch numbers and they ruined my paint in the summer heat. The magnetic sheet gets so hot in the summer sun, it appears to have baked the clear coat on my doors.
I was able to smooth it out a bit with some compound, but the damage is still visible from an angle.
Static cling and reuseable low tack stick on vinyl are alternatives to magnetic.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 08-22-2006, 06:10 AM
Call the guy that organizes the DEs for your local chapter. Odds are, he has a supply ready to go. I got my magnetic numbers from our DE organizer that way. He had them waiting for me at my first DE. Fifty bucks.
Old 08-22-2006, 07:39 AM
Cory M's Avatar
I went to edecals.com
Old 08-22-2006, 08:33 AM
