Fender well coating and joint sealer
I am looking for a good product that I can spray at home similar to truck bed lining that I can coat my inside fender wells to avoid damage from rocks being thrown up and dinging the inside of the fender (and the paint outside). Any success stories?
Also, a spray can sealer that I could use to seal body panels and crevices that paint will still adhere to.. The factory clearly used some type of spray...ideas?
Paul S "Those who say it cannot be done should not interrupt the people doing it" |
I think wurth is the factory sealer, you need a special wurth gun though to apply it which is different to a normal schults gun.
EDIT also available as an arerosol http://www.pelicanparts.com/catalog/shopcart/GADG/POR_GADG_WUGARG_pg15.htm Steve
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 Last edited by 1972_911T; 08-18-2006 at 11:03 AM.. |
You could use the factory WURTH coating. It is either stone guard or SKS. It comes in bottles and you spray with a special nozzle.
Doug
1971 RSR - interpretation |
