LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average.
dorschman's Avatar
couple of questions about bumperette removal
looked through a couple of old threads and I like the look without the rear bumperettes. My question is on an 87 Carrera there are license lights to deal with. Do the bumperettes just unscrew and the wires for the lights can be taped or is there more to it? I would like to try but not if it requires modifications or major changes to the car.
thanks
erik
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 08-17-2006, 07:03 PM
Eric-325I's Avatar
For most of us, lighted plates are required by law.
Many of the threads I've read indicate that owners disconnect the original light 'fixtures' and replace them with something else either mounted to the bumper or with lighted plate frame bolts. Some are very creative in sourcing the fixtures... Thought I read that one guy nabbed some lights from the rear of a Honda or the like at a junkyard, painted them, and mounted them on the bumper. Looked great too! I'll be using the lighted liscense frame bolts...
Eric
'79 SC Silver over Black... Sold
Old 08-17-2006, 07:47 PM
wcc wcc is offline
wcc's Avatar
This is too funny cause I JUST removed my bumperettes last night! I unbolted it, used a rubber mallet and tapped on the studs to free them. Unscrewed the lights and unhooked the wires. It already looks a ton better! I have a few holes to fill/cover and I'm set. Very easy removal process.
Ok, as for lighting the new set up here are a couple of links that I liked. It depends on your preference of course. But here's what I just ordered:
http://www.billetspecialties.com/item.asp?cid=6&scid=187&pid=244
Some other options:
Brushed Aluim:
http://www.stylinconcepts.com/part.aspx?partid=35600&scid=affprod
Black:
http://www.***************/productpage.aspx?pid=103489&name=Illuminated+Frame
Bill
997.2
Old 08-17-2006, 07:57 PM
TWork's Avatar
I think it's just 3 13mm nuts on each bumperette and a mallet as Bill suggests.
'73 Targa
Old 08-17-2006, 09:24 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
I like the illuminated frames, do Pelican not stock these??
Bill, I could not see from the link, but the last link to the black frame - is it aluminium or plastic??
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 08-18-2006, 01:37 AM
wcc wcc is offline
wcc's Avatar
I'm not sure if that black plate is plastic or alum. I wanted a polished frame so I didn't look into that one that much. It was just the first one I found. I looked on Pelican, but I couldn't find any.
Bill
997.2
Old 08-18-2006, 03:44 AM
coolcavaracing.com
Kroggers's Avatar
Thanx for the info Bill
Old 08-18-2006, 03:49 AM
dorschman's Avatar
thanks guys. that helps a lot. I think I may try it this weekend and look into the black plate.
erik
87 911 coupe "Katy"
Summer Yellow
Old 08-18-2006, 04:04 AM
wcc wcc is offline
wcc's Avatar
Paul - No problem. Hope some if it helps......
What time is it over there? Cause it seems like we are on about the same time. It's 7am here...
Bill
997.2
Old 08-18-2006, 04:05 AM
coolcavaracing.com
Kroggers's Avatar
It is 1pm, and I have just had my lunch
Old 08-18-2006, 04:19 AM
dorschman's Avatar
yeah, I'm drinking my coffe and about to go to work. Maybe I should live in Sweden today.
erik
87 911 coupe "Katy"
Summer Yellow
Old 08-18-2006, 04:21 AM
wcc wcc is offline
wcc's Avatar
I Think I work too early (6:30am)! I had breakfast a couple hours ago. See you guys later, gotta get back to it!
Erik - Let us know if that black plate is metal or plastic. I'm just curious too.
Bill
997.2
Old 08-18-2006, 04:33 AM
This might answer some of your questions.
Extreme Makeover, Carrera bumper
Old 08-18-2006, 06:52 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I dont do much night driving....my tag is reflective....so i dont have tag lights on mine
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 08-18-2006, 09:53 AM
Rick964's Avatar
Do you have any pictures of the bumper minus the bumperettes before you patch all the holes? I am curious just what work to patch up would need to be done.
Old 08-18-2006, 11:10 AM
Counterclockwise?
Can you not buy bumper plugs?
It would get you through until you needed paint.
Rod
1986 Carrera
2001 996TT
Old 08-18-2006, 11:50 AM
Jean Berk's Avatar
I'd recommend having the unwanted holes TIG welded up - here's mine before paint - no filler, just abrasive-wheeled...
Old 08-18-2006, 12:04 PM
wcc wcc is offline
wcc's Avatar
Rick964 - Here's a pic of the bumper without the bumperettes. There are 3 holes to fill. But in my case I'm going to drill a hole right behind the plate frame so I can hook up the license plate light.
911Rod - Yes there are body plugs out there that would work and you could touch up around the holes and paint the plugs to get you though till paint. But it really depends on what's going on with the corrosion behind the bumperettes. One side doesn't look too bad whereas the other side could use paint.
Jean Berk - This bumper is Alum and is actually pretty thick. Could you use a MIG welder to weld in the Alum rods? Solid core wire with gas. That's what I was planning on doing.
On a side side note: Here's a welding question before I go blind! If I have a auto darkening helmet (1/20000 sec) can I watch as I strike the arc or am I'm going to hurt my eyes?
dorschman - Really, I'm not trying to hijack your thread just trying to get more info for everyone thinking of this project. Great Thread by the way!
Bill
997.2
Old 08-18-2006, 07:02 PM
Jean Berk's Avatar
Not sure about MIG welding in ally - tried it once without much success. No harm in trying on the inside of the bumper though...
Old 08-19-2006, 07:04 AM
All the circled holes needed filled. The 2 horizontal holes are where the studs added to the inside.
Old 08-19-2006, 07:13 AM
