Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
"early" 915 input shaft seal....
looks like the 72-76??? 915's don't have the removable sleeve on the input shaft ....to replace the seal you gotz to gut the tranny to get to it ??? I've been told that you can also use a "special tool" (piece of correct size pipe) & just tap the old one back down the shaft into the tranny & tap a new one in to replace it...no harm, no foul, no $$$$$ to gut & reseal the whole tamn dranny !!!! anyone know 'bout this or have experience??? my 915 is a '75...shifts "like butta" & only leaks a little from the seal...hate to tear into it !!!
Greg....PCA, 356 Registry, 912 Registry 1977 911S Targa with 3.2...1960 T-5 coupe 1968 912 coupe, that's 32 P-cars, so far... 1990 Chevy 4x4 2500 pickup (with 255K & still rockin') |
on my past 75 car, i did it while leaving the tranny in place. you disconnect the coupler via the set screw, then climb under the car with various tools. picks, small screwdrivers, etc. then pick away like a man posessed. you want to be careful not to mar any sealing surfaces, but with patients, you will pop that sucker out. believe me, you wont know whether to cry or laugh. it is a good feeling. took me about 30 minutes of picking. and the second you start, you get the "point of no return" feeling. once it is out, you put the new one over the shaft with a little bit of silicon lube and push it on. it is way easier on, than off. i didnt have any special tools. i just work slowly around with a flat blade screwdriver and pressed it on.
poof! gone |
"looks like the 72-76??? 915's don't have the removable sleeve on the input shaft ....to replace the seal you gotz to gut the tranny to get to it ??? I've been told that you can also use a "special tool" (piece of correct size pipe) & just tap the old one back down the shaft into the tranny & tap a new one in to replace it...no harm, no foul, no $$$$$ to gut & reseal the whole tamn dranny !!!! anyone know 'bout this or have experience??? my 915 is a '75...shifts "like butta" & only leaks a little from the seal...hate to tear into it !!!"
I assume you are referring to the input shaft seal (input shaft being the one carrying power from the engine to the transmission) as opposed to the to the shift shaft seal which is what I believe Vash is describing. The special "apple corer" tool is required to do the input seals from the outside on the some of the '72- early '73 915s and is supposedly helpful on some of the later fixed sleeved 915's. I've always replaced the fixed sleeve (this is the sleeve the clutch throw out bearing operates on) input shaft seals when I've had the transmissions apart. On my '76 915 the sleeve was removable which might also be the case on your '75. I don't recall when the transition to the removable sleeve was made. Whatever the case, to replace this seal you will need to at least drop the engine - I prefer to drop the engine and transmission as a unit. |
Yes Jim...thanks, I am referring to the input shaft seal!!! I've already pulled the 2.7 & trans in prep to install my new 2.7....the tranny has already been through the steam washer & is all shinny clean..er, make that dull grey clean ( magnesium don't shine much). Now's the time to replace that seal & a P-car guy I know told me @ the trick way of replacing it as I state above...was just hoping there were other sucesses with this technique out there in Pelican Land....
It's done !!! & it worked just fine.... now, is there ANY way to make magnesium look good ????
My 2 cents to round out this thread... '72 & 73 can only change the seal from the inside (no clearance for the coring tool). '74 & 75 can use the coring tool. '76 on (?) have a removable snout.
'74 911S Ice Green '71 911T Tangerine '74 R90S Silver Smoke |
so does, I think, Michael Jackson !!!!
Warren Hall Student
![]() Mid 72', trannies numbered 733 7375, 783 0838, 793 1031, and onward all have seals that are inserted from the clutch side.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 08-18-2006 at 03:05 AM.. |
Automotive Writer/DP
Late to this thread. It was actually mid '73 (3/73 production) when the input shaft seal was changed, at least for the 915 5 speeds. I've seen an original '73 CIS T with the earlier input shaft seal gearbox. #733 7375 is a mid '73 production number, as indicated in the factory manual.
1972 S - Early S Registry #187 1972 T/ST - R Gruppe #51 http://randywells.com http://randywells.com/blog |
