Disassembling elec mirrors
My left mirror is loose , the base is tight on the door but where it splits for moving the mirrors towards the body its loose.
Does anyone know how they come apart? I can take the base off the door with a hex key but I dont see how to take it apart further |
Yes, you take the hole mirror off and underneath the base youŽll see the place to adjust. It needs an specific tool for that, I donŽt know how you call it in english.
My 76 911s is like that..... |
If its SC type, there are three pins that attatch the glass to a thin metal backing plate. Very gently pry the glass off the metal plate and you will see that there are 3-10mm(I think they are 10mm) screws that hold the plate to the mirror housing. Good luck and hope it helps.
I call it a locknut and all you need is a screwdriver to turn it clockwise to increase the spring tension.
I dunno about SC's, but my turbo mirrors actually are prised off of the backing. There are metal spring pins that just wedge themselves into holes in the backing...
Careful! |
Thanks for the replies ,
stirj has it right I took the base off the door and tightened the big screw -fixed the problem |
| All times are GMT -8. The time now is 11:45 AM. |
