 Installing hard fuel lines on a 79Sc I have sourced the steel lines to replace the soft fuel lines from the injectors to the fuel regulator,but the fittings are different. the old soft lines use a banjo bolt in the top of the regulator and the steel lines use a straight connection into the regulator with a ferrule/compression fitting. Are there threaded inserts for the fuel regulator that i can use to fit the steel lines? Thanks in advance. |
 Bump for a reply. I was looking at doing this as well. I don't think there is a threaded-type of fitting at the FD. Anyone else? |
 I have an extra set of the fittings since I'm EFI now, let me make sure I have all six and I'll PM you. |
 Scott  you have  pm . Thanks bruce |
 I did not get your PM, however these should be the guys I had to go dig them out of my CIS parts toybox: http://home.comcast.net/~sramnit/fittings.jpg You pay the shipping and they are yours! I'm EFI now so I am going to be getting rid of all of my CIS stuff. |
 Scott,  thanks much!!!!! appreciate your willingnss to help out. send me your address and i will get $10.00 in the mail My cis is running fine what do you want for your spare cis? and is it operational Why do you go EFI? did it die? more HP ? just curious thanks . you can email me your address at hbkramer@aol.com or here if you like . Thanks Again ! again. |
| All times are GMT -8. The time now is 05:34 AM. |
